Browse Forums Building A New House Re: Brick Issue with new house, rendering whole house, re-br 3Jan 18, 2019 3:42 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Brick Issue with new house, rendering whole house, re-br 4Jan 18, 2019 7:57 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Brick Issue with new house, rendering whole house, re-br 6Jan 18, 2019 8:10 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Brick Issue with new house, rendering whole house, re-br 12Oct 23, 2019 11:01 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Brick Issue with new house, rendering whole house, re-br 18Nov 07, 2019 6:24 am Hi, The main issue with staining on brickwork is efflorescence. Moisture bring salts to the surface. No “coating” will stop it properly, can really only clean off and wait, repeat or replace. If its coming through paint/stain then would come through render over time IMO re-bricking is the only solution. It will involve quite a lot of ancillary work like removal of eaves, downpipes, power outlets etc and repainting reassemble. Thnks Re: Brick Issue with new house, rendering whole house, re-br 19Nov 08, 2019 1:12 pm Mirrmu83 Hi, The main issue with staining on brickwork is efflorescence. Moisture bring salts to the surface. No “coating” will stop it properly, can really only clean off and wait, repeat or replace. If its coming through paint/stain then would come through render over time IMO re-bricking is the only solution. It will involve quite a lot of ancillary work like removal of eaves, downpipes, power outlets etc and repainting reassemble. Thnks Hi Mirrmj83, We tend to agree that a re-brick is going to be our only option at this point but we are concerned how doing this job would impact us given we are already living in the house. Could I pick your brain and ask what questions we should be asking the builder re the process and what things you think we should look out for during same. Re: Brick Issue with new house, rendering whole house, re-br 20Nov 09, 2019 9:03 am Hi, You are basically undertaking demolition and rebuild. This is not uncommon and will be very prevalent when the flammable cladding projects in Victoria commence. Going to have to catalogue a lot of things. Condition reports, 300+ photos of driveways, landscaping,, windows/doors, internal plaster. One thing to consider would be having the brick ties installed with screws instead of nails as the continue hammering of nails to frame could cause cracking to internal plaster. The builder may have to engage security to patrol/guard house from 5pm - 7am for the period when the bricks have been removed and the relaying begins. Instal CCTV., temporary toilet etc Have to have an agreement on lintels (reuse or new), everything which is removed that can go back on. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4890 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7493 |
