I think it's www.dunnandfarrugia.com.au/
but not 100% sure.
Thanks! Nothing in the product gallery that looks like what we want.
Browse Forums Building A New House Re: Building with Wisdom Homes 15247Nov 04, 2019 7:34 am J_Wess Your contract with Wisdom Homes is for them to build to your home to the applicable building standards with an acceptable standard of workmanship. The approx. $2,000 set of Housepect stage reports identify non compliant items where these building standards have not been met. I used Housepect for both stage inspections and some investigations. I found their inspectors enthusiastic and patient enough to explain all the items that I didn’t understand in the report over the phone, including the importance of each and likely builder response. I also downloaded a copy of The NSW Guide to Standards and Tolerances 2017 [url=https://www.fairtrading.nsw.gov.au/housing-and-property/building-and-renovating/after-you-build-or-renovate/guide-to-standards-and-tolerances:kdr3ckn8]https://www.fairtrading.nsw.gov.au/housing-and-property/building-and-renovating/after-you-build-or-renovate/guide-to-standards-and-tolerances[/url:kdr3ckn8] This excellent document explains most common items in residential construction in a clear and user friendly way. I suggest first reading the sections relevant to the issues identified by Housepect then asking your SS to explain why they are important, what Wisdom will do to rectify them to meet building standards, and when & how you can check to visually confirm the necessary rectifications have been done. Keep a copy of the NSW document handy to refer to in your discussions with the SS. The SS’s dismissive responses that you mention are neither appropriate nor respectful of you as a customer. Make sure the ”Wisdom way of building” actually meets the building standards and they do what they promise before it’s too late to check or practically fix. If the SS is unable or unwilling to explain and commit to your satisfaction I suggest contacting Mark at wisdomhomes for assistance, as well as the trades experts in this forum. Ideally, and if you are comfortable, all questions and responses about defects, building standards and rectification plans would be shared publicly here to allow all others to learn and benefit from your experiences.[/quote] Re: Building with Wisdom Homes 15248Nov 04, 2019 9:49 am becks81 Thanks for that pic and testimonial. Hoping this thread hasn’t died completely as I feel the vibe has changed and many members are not willing to post anymore. I have valued so many of your posts, whether it be general discussion about your Wisdom builds or your much appreciated responses to my first time builder questions. I have a quick one, we have had to revise some kitchen joinery and have been sent a more ?complete set of drawings that we hadn’t seen before. What is this drawing of exactly? I can’t reconcile the measurements. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I don't even remember my Timplle having plinth drawings Re: Building with Wisdom Homes 15249Nov 04, 2019 7:56 pm becks81 - we have the external plumbing done since the last post. I feel the same as what you mentioned about the vibe but most of the folks who were active previously are near PCI if not already in their house. Hoping all those near PCI a smooth journey to the end ! 🥳 Re: Building with Wisdom Homes 15250Nov 05, 2019 4:58 pm I believe the vibe has changed across the whole forum. I posted extensively on my last build, however its not the same audience now. I believe everyone has moved on, i know i have a large following on instagram and I follow over a thousand builds as well. It’s very friendly and lots of people help each other out, and its not moderated, so people are probably more open to say what they want. Re: Building with Wisdom Homes 15251Nov 06, 2019 8:01 pm Need some help from those who are building Manhattan. Our plans show a closed up view of the stairs (as indicated in red) which our CSR did say it's not accurately reflected and not to worry about it. Anyone who has completed their stairs, have the underneath of the stairs sealed and are using glass baluster? Can you share a photo? I assume the glass baluster should go all the way up..? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 15252Nov 06, 2019 8:09 pm M4bath Need some help from those who are building Manhattan. Our plans show a closed up view of the stairs (as indicated in red) which our CSR did say it's not accurately reflected and not to worry about it. Anyone who has completed their stairs, have the underneath of the stairs sealed and are using glass baluster? Can you share a photo? I assume the glass baluster should go all the way up..? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Not quite finished and stairs will have carpet Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 15253Nov 06, 2019 8:33 pm Manhattan52 M4bath Need some help from those who are building Manhattan. Our plans show a closed up view of the stairs (as indicated in red) which our CSR did say it's not accurately reflected and not to worry about it. Anyone who has completed their stairs, have the underneath of the stairs sealed and are using glass baluster? Can you share a photo? I assume the glass baluster should go all the way up..? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Not quite finished and stairs will have carpet Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ First of all - WOW! That is some sexy looking stairs. Secondly, your photo helped clarify the glass baluster should go all the way up to my squiggly line is as per picture below. Now I can sleep better tonight. Phew. Thank you! Did you get a PCI date yet? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 15254Nov 06, 2019 8:41 pm M4bath Manhattan52 M4bath Need some help from those who are building Manhattan. Our plans show a closed up view of the stairs (as indicated in red) which our CSR did say it's not accurately reflected and not to worry about it. Anyone who has completed their stairs, have the underneath of the stairs sealed and are using glass baluster? Can you share a photo? I assume the glass baluster should go all the way up..? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Not quite finished and stairs will have carpet Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ First of all - WOW! That is some sexy looking stairs. Secondly, your photo helped clarify the glass baluster should go all the way up to my squiggly line is as per picture below. Now I can sleep better tonight. Phew. Thank you! Did you get a PCI date yet? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ No specific date but should be in about a fortnight or so. Painting nearly finished, waiting on carpenters to come back and finish a few things. Carpets are booked so shouldn’t be too long Re: Building with Wisdom Homes 15255Nov 07, 2019 6:57 am Hi manhattan52 I am looking forward to your PCI in a few weeks time. Your house looks awesome! Who is your private building inspector? I think in an earlier post you mentioned your plan to appoint one. When will you schedule their next stage inspection for? Just before PCI? Any suggestions for members about this?
Re: Building with Wisdom Homes 15256Nov 07, 2019 8:54 am M4bath Manhattan52 M4bath Need some help from those who are building Manhattan. Our plans show a closed up view of the stairs (as indicated in red) which our CSR did say it's not accurately reflected and not to worry about it. Anyone who has completed their stairs, have the underneath of the stairs sealed and are using glass baluster? Can you share a photo? I assume the glass baluster should go all the way up..? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Not quite finished and stairs will have carpet Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ First of all - WOW! That is some sexy looking stairs. Secondly, your photo helped clarify the glass baluster should go all the way up to my squiggly line is as per picture below. Now I can sleep better tonight. Phew. Thank you! Did you get a PCI date yet? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Designer Staircases would have provided you with detailed drawings of your staircase - you should double check against those drawings. Re: Building with Wisdom Homes 15258Nov 08, 2019 5:52 pm manhattan52 Are you likely to finish within your contracted timeframe? Re: Building with Wisdom Homes 15259Nov 08, 2019 6:15 pm One @manhattan52 Are you likely to finish within your contracted timeframe? After calculating rain days From BOM and shutdowns for Xmas as well as extension of time for building variations would be a few weeks over which is pretty good considering the scope of landscaping works being undertaken Re: Building with Wisdom Homes 15260Nov 08, 2019 8:20 pm Manhattan52 One @manhattan52 Are you likely to finish within your contracted timeframe? After calculating rain days From BOM and shutdowns for Xmas as well as extension of time for building variations would be a few weeks over which is pretty good considering the scope of landscaping works being undertaken Glad you are happy with it 😆 How do you calculate rain days from BOM? Is it rain over a certain amount? I also didn’t know there is time extension for building variations. We have some but hopefully not too significant for delays. Were you informed of how much time would be factored in for these building variations? We are hesitant to do further landscaping works with Wisdom as we really don’t want to take any longer to move in. Still undecided... Can we move in without a driveway? Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73519 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8241 |
