Browse Forums Building A New House 1 Oct 27, 2019 4:44 pm Hi Guys, It might sound crazy. But due to the lack of knowledge about building a new home, we overlooked and we didn't ask for a treated timber for our new home. When the frames were delivered and put up, we realised how different it is from other houses as the wood looks natural in colour(stamped as MGP10) unlike others we've seen as greenish. Later we found out that it wasn't specified as treated timber in our tender, and we didn't ask as we don't have any idea at the time. Now that it's too late, has anyone or is it possible for me to just apply some sort of chemical to the wood base(attached to the slab) just to minimise potential dangers from termites? Don't know also if our builder will even allow me to. But would be happy if at least anyone here has tried? Could there be any product in bunnings i can or anyone has tried? Thanks in advance Re: Can I DIY my untreated timber frames? 2Oct 30, 2019 9:14 am Hi Superfly1130 Check to see that you have all the certified engineering Details and notes under timber treatments..if not your council should have copies. The chemicals used to treat the timber are toxic and you can't DIY...hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Can I DIY my untreated timber frames? 3Nov 02, 2019 10:03 am Thanks. I know I haven't seen any topic related to DIY ing their timber frames. Thanks for the feedback Having double brick already gives you better thermal insulation and sound proofing compared to a brick veneer with insulation. The insulation is added because the wall is… 5 1458 Any owner builders out there gone through the process of building their own window frames on a new build? Any advice would be welcome in terms of ensuring approval by… 0 1351 Dear Jitender. The gap is required as per Australian Standard 4773.2 part 7. It came into effect in May 1 of 2012. The SA builders are only just starting to pick up on… 5 1779 |
