Browse Forums Building A New House Re: Mojo Homes 1212Oct 30, 2019 11:45 pm Tender stage with Mojo - they took me for a ride just for providing quotation. Hopeless document with so many mistakes; had to write up a huge list of corrections every time. Close to finalising. How are you all travelling with your build? Any word of caution from anyone throughout the process? Thanks in advance for sharing! Re: Mojo Homes 1214Nov 26, 2019 1:12 pm Hi, Can someone advice how the NBN connection will work. Mojo says they will provide the connection upto the house. But how or rather who will wire the NBN box that will be located inside the house. Wouldn't that mean drilling into the walls again?? Re: Mojo Homes 1215Nov 27, 2019 9:38 am JamesW Hi, Can someone advice how the NBN connection will work. Mojo says they will provide the connection upto the house. But how or rather who will wire the NBN box that will be located inside the house. Wouldn't that mean drilling into the walls again?? Assuming the NBN connection is Fibre-To-The-Premises (FTTP) - Once the NBN Co contractors have installed an NBN PCD (external fibre junction box) on the outside wall of your property, you will be notified that you are able to connect to the NBN. You then need to contact an NBN Service Provider and sign up for an NBN service plan. They will organise for the new internal NBN equipment to be installed in your home. Once the NBN internal equipment has been installed, you are ready to go. You just connect an NBN compatible router to the Uni-D1 port of the new NBN equipment. My builder provided NTD as well, so it was much easier. In your case, I suggest you go with established provider like Telstra, Optus, TPG as their contractors will do a good job on the inside cabling. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Mojo Homes 1216Nov 27, 2019 12:32 pm IamSAM JamesW Hi, Can someone advice how the NBN connection will work. Mojo says they will provide the connection upto the house. But how or rather who will wire the NBN box that will be located inside the house. Wouldn't that mean drilling into the walls again?? Assuming the NBN connection is Fibre-To-The-Premises (FTTP) - Once the NBN Co contractors have installed an NBN PCD (external fibre junction box) on the outside wall of your property, you will be notified that you are able to connect to the NBN. You then need to contact an NBN Service Provider and sign up for an NBN service plan. They will organise for the new internal NBN equipment to be installed in your home. Once the NBN internal equipment has been installed, you are ready to go. You just connect an NBN compatible router to the Uni-D1 port of the new NBN equipment. My builder provided NTD as well, so it was much easier. In your case, I suggest you go with established provider like Telstra, Optus, TPG as their contractors will do a good job on the inside cabling. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks, appreciate the detail! Re: Mojo Homes 1218Nov 27, 2019 3:53 pm From 1 April 2016, the $300 New Development Fee is charged for all nbn™ broadband connections in the following circumstances: The first connection at a premises in a newly developed area i.e. a suburb with no pre-existing telecommunications infrastructure. All new NBN connections are required to pay this $300 (Telstra/Optus will include this in first invoice). This amount has to be paid only once per property. It has to be paid even if your builder provided all connections/equipments (like my case) Re: Mojo Homes 1220Nov 29, 2019 7:57 am voz Thanks but I was asking about the FTTP "inside" connection as per the diagram in the thread above. Mojo are not doing the box in my garage so I want to know how much would it cost. Thanks All that is covered under the $300 New Development Fee. Check with Telstra / Optus if 5G is available in your area...that technology is the future and could make NBN irrelevant. Is anyone building with Mojo and have a recent site cost tender 0 15952 Hi all, We are considering Enigma 46 from Mojo Homes in Gables, NSW. Has anyone built with Mojo and any pointers and feedback. Also, if anyone has built similar design… 0 13162 Hi, We are looking for a builder that can build a small home (smaller length) on a sloping site. We came across Mojo's Zephyr design 10.6 m wide and 11.5 m length. Does… 0 23017 |
