Browse Forums Building A New House Re: Building with Wisdom Homes 15164Oct 22, 2019 9:19 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15165Oct 22, 2019 9:29 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15167Oct 22, 2019 10:11 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15169Oct 22, 2019 4:52 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15173Oct 23, 2019 10:42 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15174Oct 23, 2019 10:45 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15178Oct 23, 2019 1:32 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Building with Wisdom Homes 15179Oct 23, 2019 1:55 pm Hi Does anybody know how much extra will cost to have floorboards on the living/dining room and tiles on the kitchen floor? I understand there will have to be a sort of level adjustment due to different hight between tiles and floorboards and will attract an extra cost. Also if you can tell me how much it cost to have a color schema for the walls. I understand the inclusions allow the house to be painted only in a single color and every extra color will attract charges, but I don't know how much it will be/. Re: Building with Wisdom Homes 15180Oct 23, 2019 2:12 pm malypetu Hi Does anybody know how much extra will cost to have floorboards on the living/dining room and tiles on the kitchen floor? I understand there will have to be a sort of level adjustment due to different hight between tiles and floorboards and will attract an extra cost. Also if you can tell me how much it cost to have a color schema for the walls. I understand the inclusions allow the house to be painted only in a single color and every extra color will attract charges, but I don't know how much it will be/. with careful material selection you should be able to get your tiles and timber to sit flush. Typically engineered timber is 14-15 mm which you can either direct glue or lay on a 5mm rubber underlay A reasonable quality brand will set you back $120/sqm laid. Tiles are generally 10-12mm thick and you can have your tiler lay them on a screed which can be any thickness you like to match up to the height of the timber. You can get a nice large format tile for $50-60/sqm and tiling will cost roughly the same. So if you budget $120/sqm for everything you will be fine Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19073 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 74232 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9510 |
