Browse Forums General Discussion Re: Granny Flat 5Oct 21, 2019 5:31 am ddarroch I haven't looked into it for a few years OP, so things might have changed. But as long as the granny flat meets certain requirements, then you only need "complying developer", which is much simpler than the usual DA process. Some of these requirements are a minimum block size of 450sqm (with a frontage of at least 12m), & a maximum granny flat size under 60sqm. Thanks for your reply, Please have a look the following photos of my hour plans. I want to build granny flat on right hand side of the house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Granny Flat 6Oct 21, 2019 7:26 am Adam007 ddarroch I haven't looked into it for a few years OP, so things might have changed. But as long as the granny flat meets certain requirements, then you only need "complying developer", which is much simpler than the usual DA process. Some of these requirements are a minimum block size of 450sqm (with a frontage of at least 12m), & a maximum granny flat size under 60sqm. Thanks for your reply, Please have a look the following photos of my hour plans. I want to build granny flat on right hand side of the house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sorry for typo , the word is floor plan and we want to add granny flat on left hand side of existing building. Thanks I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4094 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13880 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7177 |
