Browse Forums Building A New House Re: New home build - Custom Design WA 110Oct 18, 2019 10:02 am ![]() How does it look??? My builder just asked what ceiling style I want and he suggested shadow line!!! Re: New home build - Custom Design WA 111Oct 18, 2019 12:12 pm Ok, thanks and good to know, I go with this option !!!! Your house look so good with that open space ceiling !!! Mine, I was not account for plumbing work and my house first floor is in situ concrete, so now I loose 30cm to ground ceiling height to 1 of the living room. Wish I knew this when designing the house. Good luck to us with the rest of the work !! Re: New home build - Custom Design WA 112Oct 18, 2019 10:05 pm ![]() Ok, thanks and good to know, I go with this option !!!! Your house look so good with that open space ceiling !!! Mine, I was not account for plumbing work and my house first floor is in situ concrete, so now I loose 30cm to ground ceiling height to 1 of the living room. Wish I knew this when designing the house. Good luck to us with the rest of the work !! But even then, one of our plumbing wastes was dropped below the ceiling level, and had to be fixed. Re: New home build - Custom Design WA 113Oct 19, 2019 12:54 pm More plastering was worked on this week, including the plaster float and external render. The glazing on the residential grade windows was also installed on the ground floor. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New home build - Custom Design WA 115Oct 19, 2019 3:49 pm Your Good good !!!, outside look like a finished home. Mine still look raw, render to outside start Monday, then moulding, at the moment window and door are installing, spa baths arrive and install next week as well. Kitchen just measured today, all electrical tube as well as air cond vent/pipe running just finished. Counting down !!!! Re: New home build - Custom Design WA 116Oct 19, 2019 3:59 pm ![]() More plastering was worked on this week, including the plaster float and external render. The glazing on the residential grade windows was also installed on the ground floor. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New home build - Custom Design WA 119Oct 25, 2019 8:12 pm The oversized sliding doors were installed this week. The staircase window is still requiring installation before lockup next week. A plasterer was on site today flushing the drywall joints and starting on the shadowline cornices downstairs. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It looks a great plan! The void must make the living areas so spacious. We’ve got the hebel floor too, and it certainly is lovely and solid. 3 924 6 1137 Hi JW001 Keen to know how you went. I am looking at a very similar proposition to you - similar spend, size of home, single story etc. Did you end up locking in a… 21 3580 |
