Browse Forums Building A New House Re: Temporary Trafficable Pool Cover 2Oct 04, 2019 8:18 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Temporary Trafficable Pool Cover 7Oct 05, 2019 3:39 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Temporary Trafficable Pool Cover 9Oct 09, 2019 9:00 pm Newy-Jan KamadoJusto I’m putting a pool shell in before the build. Builder wants shell fenced (fine) and if it’s within 3m of the house they want a trafficable hard cover. “clients responsibility to provide and maintain adequate safety fencing and/or covering (hard cover) to swimming pool shell at all times throughout construction. If the proposed swimming pool shell is positioned within 3000mm of a home (&/or proposed dwelling) the client must also install a Hard trafficable pool cover” Has anyone made their own cover. I’ve been quoted 4K which is absurd. Thoughts, experiences, recommendations - muchly appreciated. Hey KamadoJusto, We had similar situation - my other half built a cover for our pool shell during house build. Simple wooden frame around outside of pool, with a cross piece approx every 2m (70 by 30ml ply framing) and then corrugated iron sheets screwed down to wood. It ain't pretty but it's lasted the duration - 15 months at this point. Did you get it certified? And by who? Thanks Re: Temporary Trafficable Pool Cover 10Oct 10, 2019 5:47 am KamadoJusto Newy-Jan KamadoJusto I’m putting a pool shell in before the build. Builder wants shell fenced (fine) and if it’s within 3m of the house they want a trafficable hard cover. “clients responsibility to provide and maintain adequate safety fencing and/or covering (hard cover) to swimming pool shell at all times throughout construction. If the proposed swimming pool shell is positioned within 3000mm of a home (&/or proposed dwelling) the client must also install a Hard trafficable pool cover” Has anyone made their own cover. I’ve been quoted 4K which is absurd. Thoughts, experiences, recommendations - muchly appreciated. Hey KamadoJusto, We had similar situation - my other half built a cover for our pool shell during house build. Simple wooden frame around outside of pool, with a cross piece approx every 2m (70 by 30ml ply framing) and then corrugated iron sheets screwed down to wood. It ain't pretty but it's lasted the duration - 15 months at this point. Did you get it certified? And by who? Thanks I don't think that our cover had to be certified. But we also had the pool fenced before the build started so not sure if that made a difference? Re: Temporary Trafficable Pool Cover 11Oct 11, 2019 2:24 pm KamadoJusto I’m putting a pool shell in before the build. Builder wants shell fenced (fine) and if it’s within 3m of the house they want a trafficable hard cover. “clients responsibility to provide and maintain adequate safety fencing and/or covering (hard cover) to swimming pool shell at all times throughout construction. If the proposed swimming pool shell is positioned within 3000mm of a home (&/or proposed dwelling) the client must also install a Hard trafficable pool cover” Has anyone made their own cover. I’ve been quoted 4K which is absurd. Thoughts, experiences, recommendations - muchly appreciated. Hey Our pool is also going in before construction, roughly the same size too at 8.2 x 6.5. Our builder has said that the cover must meet OH & S guidelines - which is fine, I expect it to as well. Our pool contractor supplies the covers, says it's mostly frame, yellow tongue floorboards and sheet metal. Whole thing was about a grand. Not sure who exactly would CERTIFY a temporary cover. And why a fence and cover? Fence I can understand if the house is within 3000 of the pool as they'll have scaff etc up and need to move around. Both seems a bit OTT. Our pool guy did warn us though, that uncovered pools of the past (as in just fenced) did tend to become a dumping ground for the builders rubbish, and lunch remnants (milk cartons, food wrappers etc) YUCK. https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Temporary Trafficable Pool Cover 12Oct 13, 2019 7:30 pm Blacktea2sugars KamadoJusto I’m putting a pool shell in before the build. Builder wants shell fenced (fine) and if it’s within 3m of the house they want a trafficable hard cover. “clients responsibility to provide and maintain adequate safety fencing and/or covering (hard cover) to swimming pool shell at all times throughout construction. If the proposed swimming pool shell is positioned within 3000mm of a home (&/or proposed dwelling) the client must also install a Hard trafficable pool cover” Has anyone made their own cover. I’ve been quoted 4K which is absurd. Thoughts, experiences, recommendations - muchly appreciated. Hey Our pool is also going in before construction, roughly the same size too at 8.2 x 6.5. Our builder has said that the cover must meet OH & S guidelines - which is fine, I expect it to as well. Our pool contractor supplies the covers, says it's mostly frame, yellow tongue floorboards and sheet metal. Whole thing was about a grand. Not sure who exactly would CERTIFY a temporary cover. And why a fence and cover? Fence I can understand if the house is within 3000 of the pool as they'll have scaff etc up and need to move around. Both seems a bit OTT. Our pool guy did warn us though, that uncovered pools of the past (as in just fenced) did tend to become a dumping ground for the builders rubbish, and lunch remnants (milk cartons, food wrappers etc) YUCK. Thanks mate. Does the builder require any paperwork to state it meets OHS. Or is it a visual inspection. I’ll have no issue having it to spec. When I’m done you’ll be able to drive a car over it if they wanted too. But it’s the certification/OHS standards I’m struggling with now. Re: Temporary Trafficable Pool Cover 13Oct 13, 2019 8:24 pm KamadoJusto Blacktea2sugars KamadoJusto I’m putting a pool shell in before the build. Builder wants shell fenced (fine) and if it’s within 3m of the house they want a trafficable hard cover. “clients responsibility to provide and maintain adequate safety fencing and/or covering (hard cover) to swimming pool shell at all times throughout construction. If the proposed swimming pool shell is positioned within 3000mm of a home (&/or proposed dwelling) the client must also install a Hard trafficable pool cover” Has anyone made their own cover. I’ve been quoted 4K which is absurd. Thoughts, experiences, recommendations - muchly appreciated. Hey Our pool is also going in before construction, roughly the same size too at 8.2 x 6.5. Our builder has said that the cover must meet OH & S guidelines - which is fine, I expect it to as well. Our pool contractor supplies the covers, says it's mostly frame, yellow tongue floorboards and sheet metal. Whole thing was about a grand. Not sure who exactly would CERTIFY a temporary cover. And why a fence and cover? Fence I can understand if the house is within 3000 of the pool as they'll have scaff etc up and need to move around. Both seems a bit OTT. Our pool guy did warn us though, that uncovered pools of the past (as in just fenced) did tend to become a dumping ground for the builders rubbish, and lunch remnants (milk cartons, food wrappers etc) YUCK. Thanks mate. Does the builder require any paperwork to state it meets OHS. Or is it a visual inspection. I’ll have no issue having it to spec. When I’m done you’ll be able to drive a car over it if they wanted too. But it’s the certification/OHS standards I’m struggling with now. Ask for details. State that you are more than happy to comply, but to who exactly? https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 There are no other options other than installing a void protection, over the pool 3 949 Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3947 Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1862 |
