Browse Forums Building Standards; Getting It Right! Re: New house slab work quality in doubt 3May 25, 2019 9:18 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New house slab work quality in doubt 6Oct 06, 2019 7:36 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New house slab work quality in doubt 8Oct 07, 2019 9:05 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New house slab work quality in doubt 11Oct 07, 2019 10:18 am SMcphee I checked engineer spec, every thing seem fine except the uneven thickness of the upper floor slab and uneven height of both ceiling. Uneven heights of the ceiling below the slab Should be shown on the engineering suspended Slab Drawings All suspended slabs should be inspected and certified by an Engineer was this not done? SMcphee Is the strength of the house compromise because of this ??? As I said it could be a dropped soffit slab, which is thicker ? Inspecting the slab reinforcement after the concrete pour requires Specialist Steel detection/measuring Equipment Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New house slab work quality in doubt 12Oct 07, 2019 6:19 pm StructuralBIMGuy SMcphee I checked engineer spec, every thing seem fine except the uneven thickness of the upper floor slab and uneven height of both ceiling. Uneven heights of the ceiling below the slab Should be shown on the engineering suspended Slab Drawings All suspended slabs should be inspected and certified by an Engineer was this not done? SMcphee Is the strength of the house compromise because of this ??? As I said it could be a dropped soffit slab, which is thicker ? Inspecting the slab reinforcement after the concrete pour requires Specialist Steel detection/measuring Equipment Cheers Chris The slab on right hand side is 5cm thicker than left hand side, not really sure about dropped soffit. I think certifier due to check including this this week before roof install. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: New house slab work quality in doubt 13Oct 07, 2019 6:33 pm I'm not an engineer but have been in the building industry for 30 years. Without seeing your engineering drawings I'd say that the slab on the right is over an open plan area and as such is often 258mm (3 course) to take the span. We had a mix of 172mm (2 course) across smaller spans but required 258 across our open plan living in our last house that I owner built. Changes in ceiling height won't be in obvious places, it will change either side of an opening. As BIM guy said. The structural steel reinforcement should have been inspected by the structural engineer and signed off. Your builder should have this. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: New house slab work quality in doubt 14Oct 08, 2019 10:09 am Hi SMcphee Thanks for the photo Your photo has highlighted potentially another issue with with varying Soffits ( Below Ceiling Heights) at wall junctions, namely the placement of the slip joints which allows for movement alleviating the potential for brick wall cracking. BTW Take photos for future reference, so you will have a case for claims outside of the warranty period hth Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: New house slab work quality in doubt 15Oct 08, 2019 5:36 pm StructuralBIMGuy Hi SMcphee Thanks for the photo Your photo has highlighted potentially another issue with with varying Soffits ( Below Ceiling Heights) at wall junctions, namely the placement of the slip joints which allows for movement alleviating the potential for brick wall cracking. BTW Take photos for future reference, so you will have a case for claims outside of the warranty period hth Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wow, Thanks so much for this, definitely outside of my knowledge. Tomorrow the tile roof is on. As scheduled, Certifier must have checked it today prior to tile roof. Wondering if certifier checked on !!! Re: New house slab work quality in doubt 16Oct 08, 2019 5:40 pm chippy I'm not an engineer but have been in the building industry for 30 years. Without seeing your engineering drawings I'd say that the slab on the right is over an open plan area and as such is often 258mm (3 course) to take the span. We had a mix of 172mm (2 course) across smaller spans but required 258 across our open plan living in our last house that I owner built. Changes in ceiling height won't be in obvious places, it will change either side of an opening. As BIM guy said. The structural steel reinforcement should have been inspected by the structural engineer and signed off. Your builder should have this. Thanks, you quite right, the right side is an open plan. I can sleep now. Much appreciated and thanks again !!! I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10098 13 6632 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3502 |
