Browse Forums General Discussion Re: floor plan dimensions question 9Oct 05, 2019 12:46 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: floor plan dimensions question 12Oct 05, 2019 2:44 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: floor plan dimensions question 15Oct 06, 2019 7:05 pm easty So, should we complain if the actual is not the same as the plan? Well, it depends on what you agreed to in the contract. If they can argue they have given you what the plans specified and those plans were included in the contract, then you are getting what you agreed to pay for. However, if the measurement deviate from the agreed contract, then you have grounds for a complaint, or at least an opening to discuss options. Unfortunately, it may be too far gone for an easy rectification, but you can always use this breach as an "ace up your sleeve" to negotiate something else that might be of more importance you. Sometimes winning a principle might be satisfying, but gets you nothing. Sometimes wining on pragmatism might not feel as good, but can get you something really worthwhile. Re: floor plan dimensions question 16Oct 06, 2019 8:47 pm easty chippy All construction plan measurements are from wall to wall, whether that be framing member to framing member or brick to brick. No construction plan would be from centre of wall to centre of wall, it's just not how it's done. So, should we complain if the actual is not the same as the plan? The plans are the plans and the builders can't just change them on the fly. You mentioned 100mm. That's a huge variation. You can forgive maybe 10mm here or there but basically a good build will be mm accurate and square. If you can read a plan (where measurements start and stop) and can measure accurately and you are certain that the as built doesn't match the plans then I'd definitely be bringing it to the builders attention. Getting measurements right is the very basics of building. If they can get that right it makes it hard to trust in anything else they may do. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: floor plan dimensions question 17Oct 10, 2019 9:57 am Thanks everyone for the input. We had an independent inspection done yesterday and the inspector said that the room dimensions are alright. We measured the windows incorrectly as we only measured the window openings and apparently the dimensions in the drawings include the frame or bricks (or something). Sorry, I forgot the technical terms. Re: floor plan dimensions question 18Oct 10, 2019 11:45 am That's good to hear. I thought the reason for seeming differences may have been what you mentioned. Unless you understand plans and building it's those small details that can catch you out. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17287 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25172 Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have… 4 12510 |
