Browse Forums General Discussion Re: DIY paving entertainment area 8Oct 06, 2019 7:10 am paving is pretty straightforward and longer lasting than decking, decks cannot be close to ground because there is inadequate ventilation which is what your builder said. Paving will last 30 years with no maintenance while a deck needs recoating in 3-5 years and replacement in 10-15, cheers Pulse CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16762 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12551 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5784 |
