Browse Forums Outdoor Living 1 Oct 03, 2019 7:38 am Unsure if my previous post worked.. Building a lean to off my shed and have a few concerns. Fascia is 180x30 anchored to the shed and tied down into each pillar / concrete filled. Joists are 90x35 with 600mm spacing. Concerns are the ammount of joists hangers and the use of pryda 12g 35mm connector screws. The job is not finished, any advice would be great. The idea for joist hangars was so i can have a ceiling and the roof will use staggered metal hats for fall. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Concerns flat roof lean to 2Oct 03, 2019 10:23 am Hi Dan. Looking at the picture it looks like you have used 90mm there for the span, is that correct. If you have, it is way under specced and you are going to have huge problems. It's simply doesn't meet code. Did you consult timber span and roofing codes? What is the distance from the top to the bottom? It looks like it's over 4 metres. Maybe I'm missing something but I think you may be in trouble if you proceed. I'd swear from the picture it already looks like it is sagging in the middle just holding its own weight. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Concerns flat roof lean to 3Oct 03, 2019 10:56 am Hi Dan87 Welcome to the forum You will require Planning & Engineering designs/details and Certification for that At a glance it is under Engineered... I'd say Chippy's spot on it's sagging now and it will only get worse Thanks for the photo Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concerns flat roof lean to 5Oct 03, 2019 11:09 am If that's is an Illegal non compliant structure you will have a much bigger issue than the screws used Structurally it's not fit for purpose & Council will make you pull it down. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Concerns flat roof lean to 7Oct 03, 2019 2:43 pm Hi Dan. Any structure like your building needs council approval which will guarantee that the structural (and planning) side of the build is correct. It may seem like a pain but in the long run it's best. Good on you for pulling it down and progressing correctly. You were going to run into some serious issues if you went forward. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Concerns flat roof lean to 8Oct 03, 2019 4:10 pm Good Move as It's not worth the hassle with Council OT here is why 1.The Councils Unauthorised and Building Compliant Department checks annual aerial photos which Flags Illegal structures 2.They will inspect the unauthorised works and ask you for retrospective Planning and Building Approvals 3.The application also requires a certificate from an Engineer certifying the structure is fit for purpose 4.The Carpenter is long gone and won't be back to fix the issues 5.The council instigates legal action against the home owner Goodluck with that...hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12123 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14635 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7041 |
