Hi I am new on this forum and would like to have some advise on our custom design plan. Any input from experienced people will be much appreciated.
Browse Forums Building A New House Re: Custom plan 7Oct 01, 2019 5:33 pm No worries at all. Hey in reference to the ensuite door swinging onto the window....this is relate to BED1. Any reason this is the only bathroom with a hinged door and not a CSD?\ I just think if you tend to leave that door open, which makes sense generally for air-flow etc, then that door will always block some light and/or air if the window is open. --------------------------------------------------------------------- Check our Homeone build blog here Re: Custom plan 8Oct 01, 2019 11:20 pm Just a few thoughts myself - it's a pretty nice design, and definitely unusual to have a wider ranch style floorplan. - I see you've basically cut off two bedrooms on one side of the house with the other two bedrooms on other side of the house. Are there two families living there? - Also not only do you see the kitchen when you walk through the front door, you actually see straight through the house to the back garden, which can be a bit odd (and very bad feng shui!) - The pillar in between the entry and the family room, and the pillar between the family and bedroom 3, are they really necessary? Having an odd pillar here or there doesn't seem to add very much to the open plan. - And did you know you have a total of 5 linen cupboard/ rooms? Do you really have than much linen?! My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Custom plan 9Oct 02, 2019 5:53 pm ben888 Just a few thoughts myself - it's a pretty nice design, and definitely unusual to have a wider ranch style floorplan. - I see you've basically cut off two bedrooms on one side of the house with the other two bedrooms on other side of the house. Are there two families living there? - Also not only do you see the kitchen when you walk through the front door, you actually see straight through the house to the back garden, which can be a bit odd (and very bad feng shui!) - The pillar in between the entry and the family room, and the pillar between the family and bedroom 3, are they really necessary? Having an odd pillar here or there doesn't seem to add very much to the open plan. - And did you know you have a total of 5 linen cupboard/ rooms? Do you really have than much linen?! Thanks Ben for your comments. Yes I have two grown up kids and it’s nice to have your own space. We are building on acreage, so garden is everywhere and I am not sure how to avoid bad Feng Shui! In regards to kitchen I think it’s too late now as we have submitted plans already but I think I have to make sure this kitchen is always clean -Lol. I will be using butler pantry for most of my cooking. So hopefully not a big issue. I can’t see a way to Change it around now. So have to live with it. Re: Custom plan 10Oct 02, 2019 5:54 pm darb74 No worries at all. Hey in reference to the ensuite door swinging onto the window....this is relate to BED1. Any reason this is the only bathroom with a hinged door and not a CSD?\ I just think if you tend to leave that door open, which makes sense generally for air-flow etc, then that door will always block some light and/or air if the window is open. Good point darb 74, I will change this to CSD as well. Re: Custom plan 11Oct 02, 2019 5:58 pm gogo65 En-suite shower and toilet are too narrow, they should be a minimum 900. In fact the bedroom 3 and 4 showers seem wider than the master! The dining looks small in comparison to rest of house, make sure your table fits and you have a minimum 1m around it, for circulation space, more so, near the sliding door to outside. Are you happy to have your kitchen as the first thing people see when you walk in? I personally wouldn’t like that, but again that’s personal opinion. Good luck! Thanks for your advise. Our dining area I have measured it and should be fine to fit nice big table. Kitchen can’t be changed as already submitted our plans to council. Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25159 6 55311 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20354 |
