Browse Forums Building A New House Re: Building with Metricon 8494Sep 28, 2019 2:15 pm Kimmykim blackcat20 We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. We have creaky squeaky floors as well on the upper floor. Any reason for that? The other issue is the more intrusive one. As you step on the subfloor the noise is transferred to along the joist and causes a knocking noise along the walls. Metricon is going to lift the carpet and cut parts of the subfloor to get access to the joist and make adjustments to reduce/remove the noise. Re: Building with Metricon 8495Sep 30, 2019 8:07 am shokel1975 For those who have had handover, did M do a scrape of your block to level/evenly spread the dirt around your house? Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 8496Sep 30, 2019 8:10 am blackcat20 We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 8497Sep 30, 2019 2:44 pm Drew01 blackcat20 We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. Re: Building with Metricon 8498Sep 30, 2019 5:12 pm blackcat20 Drew01 blackcat20 We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. That'll be the anti frosting valve which will allow a trickle of water out when the temperature drops below 10 to prevent the solar collector from freezing and cracking. It's a crap design, and wastes water. When we put our garden beds in, I'm going to run the frosting valve into a wicking bed so it's not wasted water Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 8499Sep 30, 2019 5:30 pm Drew01 blackcat20 Drew01 [quote="blackcat20"]We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. That'll be the anti frosting valve which will allow a trickle of water out when the temperature drops below 10 to prevent the solar collector from freezing and cracking. It's a crap design, and wastes water. When we put our garden beds in, I'm going to run the frosting valve into a wicking bed so it's not wasted water [/quote]Ahhhh that makes sense, as we've only noticed it over the colder months. It's annoying at night. Where would we find the outlet? Re: Building with Metricon 8500Sep 30, 2019 6:00 pm blackcat20 Drew01 blackcat20 [quote="Drew01"][quote="blackcat20"]We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. That'll be the anti frosting valve which will allow a trickle of water out when the temperature drops below 10 to prevent the solar collector from freezing and cracking. It's a crap design, and wastes water. When we put our garden beds in, I'm going to run the frosting valve into a wicking bed so it's not wasted water [/quote]Ahhhh that makes sense, as we've only noticed it over the colder months. It's annoying at night. Where would we find the outlet? [/quote]It's here... A piece of PVC pipe over it to redirect it to a downpipe will reduce the noise heaps Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10930 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8374 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17670 |
