Browse Forums Building A New House 1 Sep 25, 2019 9:16 am Re: Simonds - Mebbin 25 - Melbourne North build log 4Sep 25, 2019 2:45 pm No worries Dui2705, happy to help as these are minor things that are difficult to pickup but can lead to frustration once built. In terms of converting from a standard CSD to a 'flush to jamb' version (google it as both Corinthian and Hume both supply the two versions in all sizes), the actual wall space required is another 50mm, but I am assuming by the look of your plan this will be ok. The different versions simply allow the entire door to hide away completely into the cavity, whereas standard CSDs protrude around 60mm. To get an idea if you entry space there, I would suggest measuring this out (either 560mm or 620mm depending on which version CSD) and get a feel for what it will be like. We have setup both our last houses with no door into the WIRs, just a basic plaster hamper making it feel like you are entering a different space. if you feel the risk of the gap being too small is not worth it, personally I would just remove the door and then you can make the opening as big as you want.....but I would still then ask for a plaster hamper to be built. Here is the plan for our new build with respect to no door on the WIR, and a 'Flush Fit' CSD leading into the ensuite: Our opening to the WIR is 1000mm wide, with a 200mm high plaster hamper above the opening. Our 'Flush Fit' CSD is an 820, and we get the full 820 width, otherwise with a standard CSD this width would be around 760mm.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ One other minor thing I noticed, is I would ask your SS nicely if they could install another manhole in the garage. Having one available in the garage means trades later on have access to your roof without having always drag their ladders and tools through your house. --------------------------------------------------------------------- Check our Homeone build blog here Re: Simonds - Mebbin 25 - Melbourne North build log 5Sep 26, 2019 11:30 am darb74 No worries Dui2705, happy to help as these are minor things that are difficult to pickup but can lead to frustration once built. In terms of converting from a standard CSD to a 'flush to jamb' version (google it as both Corinthian and Hume both supply the two versions in all sizes), the actual wall space required is another 50mm, but I am assuming by the look of your plan this will be ok. The different versions simply allow the entire door to hide away completely into the cavity, whereas standard CSDs protrude around 60mm. To get an idea if you entry space there, I would suggest measuring this out (either 560mm or 620mm depending on which version CSD) and get a feel for what it will be like. We have setup both our last houses with no door into the WIRs, just a basic plaster hamper making it feel like you are entering a different space. if you feel the risk of the gap being too small is not worth it, personally I would just remove the door and then you can make the opening as big as you want.....but I would still then ask for a plaster hamper to be built. Here is the plan for our new build with respect to no door on the WIR, and a 'Flush Fit' CSD leading into the ensuite: Our opening to the WIR is 1000mm wide, with a 200mm high plaster hamper above the opening. Our 'Flush Fit' CSD is an 820, and we get the full 820 width, otherwise with a standard CSD this width would be around 760mm.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ One other minor thing I noticed, is I would ask your SS nicely if they could install another manhole in the garage. Having one available in the garage means trades later on have access to your roof without having always drag their ladders and tools through your house. That's a great idea!! I have never thought of having a manhole in the Garage, but I will ask my SS about this. We are actually meeting him for the first time today at 2pm.. excited as construction is going o begin shortly!! Thanks for all your tips darb74 I really appreciate it. Re: Simonds - Mebbin 25 - Melbourne North build log 6Oct 02, 2019 5:19 pm Looks like they have started preparing the land for the slab pour.. Estimated completion for base stage as per the website is 14 October 2019... and France stage is 18 October 2019!! Re: Simonds - Mebbin 25 - Melbourne North build log 8Oct 06, 2019 8:51 pm Dui2705 Hi All, We are about to build our first home with Simonds in Melbourne's northern suburbs. Below is the timeline of activities! I will try posting progress photos regularly. So excited! We have made some updates to the original plan. Timeline: First Deposit - 26/05/2019 Second Deposit - 09/06/2019 Gallery Appointment - 10/07/2019 Contract Signing - 05/08/2019 Finance Approval - 13/08/2019 Admin Complete and Handover to Construction - 20/09/2019 To be updated as the build goes Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey - the kitchen plan looks good; we have gone with the standard layout. All the best True North Greenvale. Stage 13. Re: Simonds - Mebbin 25 - Melbourne North build log 9Oct 15, 2019 8:57 pm Re: Simonds - Mebbin 25 - Melbourne North build log 11Nov 11, 2019 9:54 am Canopus Hi dui2705 Hope all is going well with your build - any further updates to your build log? We should commence construction later this month as well. Hey Canopus! I'm sorry for not updating! It's been very busy for us, we are getting married in January so its less than two months now haha and we have so many little things to do before then! The build is going really well! I don't have a lot more photos, but the roof has gone up, the frames up as well and electrical and plumbing is complete! The bricks are scheduled to go up today, we are doing the insulation for the inner walls (soundproofing it ourselves, the site supervisor is really nice and approved us going in and doing this ourselves). The wall plasters are going up tomorrow. Everything has been happening so quick its so hard to keep up with everything haha. I'll try and update more often Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Simonds - Mebbin 25 - Melbourne North build log 13Nov 11, 2019 3:49 pm Dui2705 Canopus Hi dui2705 Hope all is going well with your build - any further updates to your build log? We should commence construction later this month as well. Hey Canopus! I'm sorry for not updating! It's been very busy for us, we are getting married in January so its less than two months now haha and we have so many little things to do before then! The build is going really well! I don't have a lot more photos, but the roof has gone up, the frames up as well and electrical and plumbing is complete! The bricks are scheduled to go up today, we are doing the insulation for the inner walls (soundproofing it ourselves, the site supervisor is really nice and approved us going in and doing this ourselves). The wall plasters are going up tomorrow. Everything has been happening so quick its so hard to keep up with everything haha. I'll try and update more often Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ congratulations dui2705 for the wedding!!! True North Greenvale. Stage 13. Re: Simonds - Mebbin 25 - Melbourne North build log 15Dec 02, 2019 2:40 pm Hi guys! Just a quick update.. the house is coming up very quick, faster than I thought haha. We are trying to keep up with everything on life and it’s really just. Update to the house - - bricks are up - doors are in - plaster wall complete - cornices and skirtings done - kitchen and vanity installed - benchtop installed Here are some photos. Take care! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 15127 Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 23156 May I ask why you chose not to use GJ Gardiner? I'm actually meeting with one of the sales guys tomorrow for an appointment. Definitely not signing anything yet… 3 13558 |
