Browse Forums Building A New House Re: Building with Wisdom Homes 15020Sep 25, 2019 1:50 pm darb74 psur2357 did anyone increase the ceiling insulation above the standard R3.5? it is very hot upstairs in summer...just wondering if I got R6.0 ceiling insulation whether would improve greatly. thanks Hi, I would google “stack effect house summer”....the extra insulation will help but most important thing I reckon is to control air leakage in/out of the building. In summer cool air drops and if it can easily leak out it causes pressure differences that will pull hot outside air in from the top. So look carefully at the obvious leak points in a building envelope. Things like evaporative cooling vents/ducts, windows not sealing properly etc. In winter the reverse happens and as hot air rises, you might open a window and then cold air rushes in from downstairs again due to pressure differences. Control temps with insulation is important but less effective if there are plenty of air leaks, and some of them are simple enough to locate and fix. I would second this. It would be worth checking if Wisdom are meant to insulate around the garage door as we had about a 1 inch gap and given we have a sliding door from Garage into Laundry and then another sliding door into the buttlers there was a lot of air movement. Just spent about $400 to get the Garage door sealed and also put a seal around the front door which was worth every cent. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18435 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73284 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8207 |
