Browse Forums Building A New House Re: Building with Metricon 8489Sep 24, 2019 5:01 pm darb74 Hi, yeah you're correct in terms of the sarking running to the gutters, as I recall with our 'breathable' version from CSR it is designed to allow moisture (condensation) to drip over it and then run down the roof to the gutter. I'm never heard any noise from houses I have lived in though (with sarking), but these were all single storey so maybe double gets that much more wind in those areas? One thing to check though is how many roof screws are along that bottom section, at the roof batten closest to the gutter. I know in ours (& our neighbour) they seem to have screws in every second corrugation of the roof sheets. Would this help with retaining the sarking better? Not sure, but worth checking I think. This image shows the increased number of roof screws in that lower section on our roof.Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This pic show under our eaves (prior to lining) and you can see the farthest batten is still a fair distance from the edge of the gutter...so I guess there is a chance wind could be flapping in around. But maybe they left too much overlap into the gutter that might make it more susceptible?Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks for your detail examples.: {I know in ours (& our neighbour) they seem to have screws in every second corrugation of the roof sheets.} I can't really check my 1st floor roof but will check my lower floor roof.. This is a good point about the screws. Re: Building with Metricon 8490Sep 25, 2019 12:13 am nthhome For my recent Northern Sydney build, Metricon used interior grade plywood for the Liberty balcony floor. They said this was their standard practice. Housepect and I didn't accept this and had them remove all the plywood and replace it with appropriate wet area fibre cement board. I checked the balcony waterproofing really carefully as well because their contractor had up to 5 attempts in most rooms to do all the internal wet area waterproofing correctly. In addition, they installed the lower portico ceiling gyprock before waterproofing the balcony (they were in a hurry to issue the fixing stage invoice) and after it rained all this and some framing timbers had to be replaced. Re: Building with Metricon 8491Sep 25, 2019 9:55 am Renman NthHome Vent for the day: before building our house we spoke to several Metricon owners and at least one said they had major issues with their front balcony. It wasn’t properly sealed and following lots of water issues it had to be rebuilt . They weren’t happy as they said they had scaffolding up for a year while they fixed it ....... I told my site supervisor I was really concerned about this issue and told we will make sure it’s done properly ..... SURE!!!! 18 months in and I have water damaged ceiling of front portico stemming from the balcony above and Metricon after months of investigations are now saying it has to be rebuilt. Great they are paying for it but far out. When will the repairs ever end !?!!! Now we just have banging noises in our joist and aircon unit that makes noisey fluid noises as it runs. Re: Building with Metricon 8493Sep 28, 2019 12:07 pm Kimmykim blackcat20 We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. We have creaky squeaky floors as well on the upper floor. Any reason for that? Re: Building with Metricon 8494Sep 28, 2019 3:15 pm Kimmykim blackcat20 We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. We have creaky squeaky floors as well on the upper floor. Any reason for that? The other issue is the more intrusive one. As you step on the subfloor the noise is transferred to along the joist and causes a knocking noise along the walls. Metricon is going to lift the carpet and cut parts of the subfloor to get access to the joist and make adjustments to reduce/remove the noise. Re: Building with Metricon 8495Sep 30, 2019 9:07 am shokel1975 For those who have had handover, did M do a scrape of your block to level/evenly spread the dirt around your house? Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 8496Sep 30, 2019 9:10 am blackcat20 We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 8497Sep 30, 2019 3:44 pm Drew01 blackcat20 We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. Re: Building with Metricon 8498Sep 30, 2019 6:12 pm blackcat20 Drew01 blackcat20 We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. That'll be the anti frosting valve which will allow a trickle of water out when the temperature drops below 10 to prevent the solar collector from freezing and cracking. It's a crap design, and wastes water. When we put our garden beds in, I'm going to run the frosting valve into a wicking bed so it's not wasted water Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 8499Sep 30, 2019 6:30 pm Drew01 blackcat20 Drew01 [quote="blackcat20"]We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. That'll be the anti frosting valve which will allow a trickle of water out when the temperature drops below 10 to prevent the solar collector from freezing and cracking. It's a crap design, and wastes water. When we put our garden beds in, I'm going to run the frosting valve into a wicking bed so it's not wasted water [/quote]Ahhhh that makes sense, as we've only noticed it over the colder months. It's annoying at night. Where would we find the outlet? Re: Building with Metricon 8500Sep 30, 2019 7:00 pm blackcat20 Drew01 blackcat20 [quote="Drew01"][quote="blackcat20"]We have constant trickling water noises in our bedroom and lots of creaky squeaky floors. That'll be the anti frosting valve which will allow a trickle of water out when the temperature drops below 10 to prevent the solar collector from freezing and cracking. It's a crap design, and wastes water. When we put our garden beds in, I'm going to run the frosting valve into a wicking bed so it's not wasted water [/quote]Ahhhh that makes sense, as we've only noticed it over the colder months. It's annoying at night. Where would we find the outlet? [/quote]It's here... A piece of PVC pipe over it to redirect it to a downpipe will reduce the noise heaps Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 3843 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 1100 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 1277 |
