Browse Forums Building A New House 1 Sep 23, 2019 9:05 pm Hi, Just got the engineers slab plans and I'm worrying (hopefully without a reason) that slab FLs are too low. Firstly garage FL is same as the dwelling (100.25). I thought dwelling slab is usually higher by 30-40mm? Also the porch is at 100.225, so lower than the garage level. Can you please give me your thought about all this? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Slab levels: garage FL same like dwelling 2Sep 23, 2019 11:42 pm It's perfectly acceptable to have your garage at the same level as the rest of your house, albeit less common nowadays. But what do you mean by the FLs are too low? Are you in a flood overlay? My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Slab levels: garage FL same like dwelling 3Sep 24, 2019 7:47 am Hi Jakez84 That is a site plan not an engineering slab plan, to avoid errors crosscheck the site Plan with the engineering Plans Please make sure you have a proper set of Engineering Plans and Details and the geotech report As mistakes can be costly OT, All engineering/construction Drawings and Details are Certified and Stamped, avoid Fake Construction Details Claiming to be compliant or an alternate engineered solution Thanks for the image Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Slab levels: garage FL same like dwelling 4Sep 24, 2019 11:15 am ben888 It's perfectly acceptable to have your garage at the same level as the rest of your house, albeit less common nowadays. But what do you mean by the FLs are too low? Are you in a flood overlay? That's what I wanted to check, I think I'm higher than the street level so that's fine, I'm not in flood prone area. It's just the neighbouring property is at 100.50 so I might get water coming from there and since mt garage is on the boundary I was worried the water can get under. The boundary footings have been designed by engineer so I think it should be fine. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Slab levels: garage FL same like dwelling 5Sep 24, 2019 11:25 am StructuralBIMGuy Hi Jakez84 That is a site plan not an engineering slab plan, to avoid errors crosscheck the site Plan with the engineering Plans Please make sure you have a proper set of Engineering Plans and Details and the geotech report As mistakes can be costly OT, All engineering/construction Drawings and Details are Certified and Stamped, avoid Fake Construction Details Claiming to be compliant or an alternate engineered solution Thanks for the image Cheers Chris Hi Chris, it shows the slab levels FL and BL so I thought it can be called slab plan, I've added the footings plan as well and borelog report. The footings are raft footings and there is a bit of an overfill as stated on the bore log so builder but I think thats should be ok. My worry was with garage level being same as dwelling but looks like that's normal. Also, the neighbouring dwelling is a bit higher so I was worried about my boundary garage that might get underflow. Also the strip footings for alfresco, I'm planning to do decking later with no slab on alfresco, would that affect the strip footings. I'm going to have perimeter path of exposed concrete all around of 900mm width including around the afresco. Just considering if I need any extra drainage along the fence with the higher neighbour and near alfresco... Also, what does Bench level mean actually? Re: Slab levels: garage FL same like dwelling 6Sep 24, 2019 1:06 pm I hope everything is going to be alright as I'm going through a big builder and they have engaged an enginner but if anyone has any comments on the plans or something I have to worry about please let know. Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6201 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11569 Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9611 |
