Browse Forums Building A New House Re: Rawson Balmoral 38 MK1 - Newcastle NSW 34Sep 23, 2019 9:04 am Week 17: Not much had happened this week as we had 3 days of rain, and on the 4th day our SS indicated the boys would need a day for it to dry out to get back into the brickwork. So I guess we only had a days work done? Our SS stated some of the scaffolding will come down shortly and they'll start work on the fascade cladding Some more brickwork completed on ground floor: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Some more plumbing done for 1st floor waste Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ One thing we contacted our site supervisor on was the number of solar panels they'd installed. On the plans we had 20 panels subtotalling 5.6kw, but they'd installed 19 panels and it looked rather odd (We thought perhaps they broke one on install) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Plan: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It turned out that we were supposed to have 20 x 280W bradford canadian solar panels installed, they've utilised the newest panels and have installed 19 x 300W bradford candian solar panels. No huge issue but still looks a bit odd, OCD types will understand! Re: Rawson Balmoral 38 MK1 - Newcastle NSW 36Sep 24, 2019 12:41 pm Yeah i did wonder about that, if I'd had known prior it would have been nice to pay the extra panel, but unsure how the wiring, inverter etc side of things if it can handle 6.0kw? Just have to put up with it I guess, wont be so noticeable I guess once our neighbour builds their 2 storey home beside us I guess! Re: Rawson Balmoral 38 MK1 - Newcastle NSW 37Sep 24, 2019 1:37 pm ourrawsonbalmoral38 Yeah i did wonder about that, if I'd had known prior it would have been nice to pay the extra panel, but unsure how the wiring, inverter etc side of things if it can handle 6.0kw?! We’ve recently designed & spec’d our own ‘10kw’ system. We have around 12.5kw of panels and Fronius 3-phase 10kw inverter. Assuming you have a 5kw inverter, with 2 input ports? You should be fine to add another 300kw panel. That ratio is still well under the 6.6kw max. Panel capacity for a 5kw inverter that Fed Govt. state is eligible for their rebate system. The inverter clips anyhow if your panels are achieving better than 5kw overall...but unlikely they actually will in reality. As the panels are linked together in a ‘series’ you should only have to add a small bracket section and it should plug ok.....as long as you use the same exact panel brand/model/capacity etc. [EDIT]...what is really 'tight-arse' about this though is the extra panel is probably only saving about $100 or so, as the STC rebates are based on panel capacity.....so you remove one panel and you also lose a few STCs rebates (values at around $40 each). So adding panels to an existing installation is not very expensive. I know because we had to remove 2 x panels due to another issue on our own system and it saved us just a few hundred dollars overall. --------------------------------------------------------------------- Check our Homeone build blog here Re: Rawson Balmoral 38 MK1 - Newcastle NSW 38Oct 01, 2019 9:25 am darb74 ourrawsonbalmoral38 Yeah i did wonder about that, if I'd had known prior it would have been nice to pay the extra panel, but unsure how the wiring, inverter etc side of things if it can handle 6.0kw?! We’ve recently designed & spec’d our own ‘10kw’ system. We have around 12.5kw of panels and Fronius 3-phase 10kw inverter. Assuming you have a 5kw inverter, with 2 input ports? You should be fine to add another 300kw panel. That ratio is still well under the 6.6kw max. Panel capacity for a 5kw inverter that Fed Govt. state is eligible for their rebate system. The inverter clips anyhow if your panels are achieving better than 5kw overall...but unlikely they actually will in reality. As the panels are linked together in a ‘series’ you should only have to add a small bracket section and it should plug ok.....as long as you use the same exact panel brand/model/capacity etc. [EDIT]...what is really 'tight-arse' about this though is the extra panel is probably only saving about $100 or so, as the STC rebates are based on panel capacity.....so you remove one panel and you also lose a few STCs rebates (values at around $40 each). So adding panels to an existing installation is not very expensive. I know because we had to remove 2 x panels due to another issue on our own system and it saved us just a few hundred dollars overall. Thanks for your informative reply! I may send our solar supplier an email and see if it can be arranged to 'buy' another panel. I guess we'd pay through the nose to get them back out though to install one panel... (if we'd had known prior I definately would have paid the extra for a 20th panel) I do know Rawson's don't allow any changes so technically whilst the qty has been changed the output would be changed? Dunno bit of a tricky one TBH? Re: Rawson Balmoral 38 MK1 - Newcastle NSW 39Oct 01, 2019 9:44 am Week 18: not much happened last week just more brickwork. We received an email from our SS (quite rare to get an update, we find out purely by going to have a squiz ourselves) that brickwork will be completed and next week they'll start on cladding, followed by render then painting. Was keen to check out the completed brickwork, so I went to take a look on the weekend. First thing I'd noticed it wasn't quite finished (just a small amount left to do in the alfresco area, and the pier column in alfresco) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I noticed the brickwork coarse was way out on the brickwork above the laundry door (yikes!) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Around the corner you could see where it was also out against the other wall.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'm hoping its just this section that's out of gauge and can be redone: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The joints on another section was quite rough: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I sent our S/S an email asking him to check this out I wasn't accepting this, he replied back saying he will get our bricklayer to inspect rip down the wall and redo it. (apparently he was on holidays and gets back today, so perhaps he had one of his coworkers do this?) Hopefully our SS delivers upon his word, unfortunately it's happened but alas the true definition of a company's service is how they respond to issues once they've been identified, and at this stage Rawson and our SS have been really good! (nevertheless still frustrating the bricklayer wouldn't have stopped work put his hand up that there was an issue!) Re: Rawson Balmoral 38 MK1 - Newcastle NSW 40Oct 01, 2019 1:26 pm That section isn't stepped down or anything is it? I guess they put more mortar per course in there? I see they will fix it, so thats good. Do you know what happens to the termite barrier when they lay the bricks? Is it meant to poke out between the slab and first course of bricks? But that means the bricks are stuck to the plastic sheet? Just started the Build process for Chifley 42 with Rawson homes, will keep you all posted with the Build progress. 0 3554 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12723 |
