Browse Forums Building A New House Re: Building with Wisdom Homes 15009Sep 20, 2019 8:21 pm becks81 How wet can the floor and gyprock get?? I’m concerned about the heavy rains we have had and the absence of some windows, front door and garage door allowing rain in this week. becks81 your floor is no issue at all. Any gyprock that has any damage will get removed and replaced no problems Re: Building with Wisdom Homes 15010Sep 20, 2019 9:49 pm Manhattan52 becks81 How wet can the floor and gyprock get?? I’m concerned about the heavy rains we have had and the absence of some windows, front door and garage door allowing rain in this week. becks81 your floor is no issue at all. Any gyprock that has any damage will get removed and replaced no problems Thanks Manhattan52. That's reassuring, I'll feel better after lock up but there still won't be a garage door. Re: Building with Wisdom Homes 15012Sep 20, 2019 10:52 pm Norfolk Check the floor is level and the gyprock walls and ceilings are straight and are not bowed, per NCC tolerance standards. Many volume builder homes are not compliant. Thanks Norfolk. I’m at that stage too now. I will certainly check. Re: Building with Wisdom Homes 15014Sep 21, 2019 9:03 am ASJ1981 Ambassador36 Hi Teezed, Actually sorry lol, I meant after the 2 days, the quotes are taking forever to come back, but we did make some minor tweeks so not totally estimating's fault. Also anyone based in Blacktown council? How long did it take to get council approval once all your selections are signed off? Anyone recently? Hoping since the building market has cooled a little the turnaround will be a little better than usual 4-6 weeks... eager to break ground and get this going asap. Thanks! Hi Ambassador36 - we are with Blacktown Council. It took 10 working days to get Council Approval - impressive, right? Plans were submitted to Council on 01/11/2018 and approved 15/11/2018. Where are you building? In regards to the Quotes, we had our selections in early March 2018, the Quotes arrived within 3-4 weeks. I think Electricals came quickest, then Colours, Di Lorenzo, Timpelle Kitchens, Landscaping, Sentinel Alarms then Actron Air. We made a few changes and amendments to all of the Quotes. And it wasn't until May (2 months later) when we finalised everything. Hope that helps! Ok thank you, was very helpful! We are building in The Ponds and praying that the council is just as speedy with us as I really am already tired out from the admin process alone and want to move in already... We have almost got all our quotes back now, we just have electricals to come back as we made some minor changes. Have you build close to us? How was your site supervisor? Hoping to get a good one as it makes a huge difference in build experience and end result. Re: Building with Wisdom Homes 15015Sep 24, 2019 10:58 pm I believe our stairs have been installed and waterproofing will be done this week. A front door has also appeared but I'm not sure how far along the internal doors, architraves, skirting has come.
Kitchen booked in 2 weeks. What order do they do things at this stage? And I forgot to ask my SS, by kitchen, do they mean all joinery or just kitchen joinery? Still looking at after Christmas but I'm ok with that, I don't want a mad rush to the end at this stage. Re: Building with Wisdom Homes 15016Sep 25, 2019 7:16 am becks81 I believe our stairs have been installed and waterproofing will be done this week. A front door has also appears but I'm not sure how far along the internal doors, architraves, skirting has come. Kitchen booked in 2 weeks. What order do they do things at this stage? And I forgot to ask my SS, by kitchen, do they mean all joinery or just kitchen joinery? Still looking at after Christmas but I'm ok with that, I don't want a mad rush to the end at this stage. All joinery will most likely be done at the same time Bec. Your wet area tiling will start soon also. You are really coming along now! Re: Building with Wisdom Homes 15017Sep 25, 2019 11:55 am did anyone increase the ceiling insulation above the standard R3.5? it is very hot upstairs in summer...just wondering if I got R6.0 ceiling insulation whether would improve greatly. thanks Re: Building with Wisdom Homes 15018Sep 25, 2019 12:20 pm psur2357 did anyone increase the ceiling insulation above the standard R3.5? it is very hot upstairs in summer...just wondering if I got R6.0 ceiling insulation whether would improve greatly. thanks Hi, I would google “stack effect house summer”....the extra insulation will help but most important thing I reckon is to control air leakage in/out of the building. In summer cool air drops and if it can easily leak out it causes pressure differences that will pull hot outside air in from the top. So look carefully at the obvious leak points in a building envelope. Things like evaporative cooling vents/ducts, windows not sealing properly etc. In winter the reverse happens and as hot air rises, you might open a window and then cold air rushes in from downstairs again due to pressure differences. Control temps with insulation is important but less effective if there are plenty of air leaks, and some of them are simple enough to locate and fix. --------------------------------------------------------------------- Check our Homeone build blog here Re: Building with Wisdom Homes 15020Sep 25, 2019 1:50 pm darb74 psur2357 did anyone increase the ceiling insulation above the standard R3.5? it is very hot upstairs in summer...just wondering if I got R6.0 ceiling insulation whether would improve greatly. thanks Hi, I would google “stack effect house summer”....the extra insulation will help but most important thing I reckon is to control air leakage in/out of the building. In summer cool air drops and if it can easily leak out it causes pressure differences that will pull hot outside air in from the top. So look carefully at the obvious leak points in a building envelope. Things like evaporative cooling vents/ducts, windows not sealing properly etc. In winter the reverse happens and as hot air rises, you might open a window and then cold air rushes in from downstairs again due to pressure differences. Control temps with insulation is important but less effective if there are plenty of air leaks, and some of them are simple enough to locate and fix. I would second this. It would be worth checking if Wisdom are meant to insulate around the garage door as we had about a 1 inch gap and given we have a sliding door from Garage into Laundry and then another sliding door into the buttlers there was a lot of air movement. Just spent about $400 to get the Garage door sealed and also put a seal around the front door which was worth every cent. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18707 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73753 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8754 |
