Browse Forums Building A New House Re: Building at Bardia - New Breeze 1163Sep 20, 2019 11:15 am Hi, 3.8m frontage. I am confused. I was assuming the minimum is 6-7. My lot is 200 sqm Re: Building at Bardia - New Breeze 1164Sep 20, 2019 12:58 pm simransindhu2001 Hi, 3.8m frontage. I am confused. I was assuming the minimum is 6-7. My lot is 200 sqm 7m frontage is a narrow block but achievable. Is it a zero lot? I think NZ89 is referring to setback. My setback is 5.9m, frontage is 10.43m but my corner block gets wider as it moves back. With a 5.9m setback my house width is 11.5m with .9m side setback on both sides. Re: Building at Bardia - New Breeze 1166Sep 20, 2019 11:05 pm as res17 Hi, I am currently buying a land in new breeze stage 3.3. I will soon be signing the land contract but before that i need some help. They have not given any registration date yet so donot know how long will it take to register. Also did any1 pay land tax even if you were a first home buyer? Also could any1 briefly give me extra cost that usually occurs during the process. Hi Asres17, when no registration date, it means takes long may be another 1-2 years. My land takes 2 years to register. For extra cost, I am not sure what you are referring to. The extra cost normally depend on your building. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 1167Sep 22, 2019 3:39 pm Gio_aus Hi guys, Did anyone here engage with 3rd party construction inspection? I got in touch with Housepect and they charge $1854 for 4 stages inspection and $2169 for 5 stages (based on house size of up to 4 bedrooms x 3 bathrooms x 3 living areas). Can anyone please recommend other inspectors who they are currently with or been referred to? I used Leon from Jim's inspection. 0450018846. For 4 stages my cost was 1900. Pretty good and knowledgeable guy. Re: Building at Bardia - New Breeze 1168Sep 22, 2019 5:04 pm Cooky simransindhu2001 Hi, 3.8m frontage. I am confused. I was assuming the minimum is 6-7. My lot is 200 sqm 7m frontage is a narrow block but achievable. Is it a zero lot? I think NZ89 is referring to setback. My setback is 5.9m, frontage is 10.43m but my corner block gets wider as it moves back. With a 5.9m setback my house width is 11.5m with .9m side setback on both sides. Hi, This is my block. Is it a zero lot? I don't think. How much will the setback me for side and front and back for this corner lot Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building at Bardia - New Breeze 1170Sep 23, 2019 9:08 am Look up "Edmondson Park South Development Control Plan 2012" especially the points under Small Lot Housing Controls. Your lot should be a zero lot. There are some new builds in Bardia (on similar lot as yours) that have made excellent use of the situation - corner lot + small lot + narrow lot + adjacent to access lane Re: Building at Bardia - New Breeze 1171Sep 23, 2019 11:52 am IamSAM Look up "Edmondson Park South Development Control Plan 2012" especially the points under Small Lot Housing Controls. Your lot should be a zero lot. There are some new builds in Bardia (on similar lot as yours) that have made excellent use of the situation - corner lot + small lot + narrow lot + adjacent to access lane Thanks, i found the doc Re: Building at Bardia - New Breeze 1172Sep 27, 2019 6:03 pm GLO Tolgz Floor space ratio Maxium is 250m2 to 300m2 block is 85% of land size. 300m2 to 450m2 is 270m2 and 450m2+ is 330m2. Floor space ratio includes the garage but excludes alfresco and porch. For secondsry building eg fonzi or granny flat land under 300m2 can only do maximuim 36m2 land 300-450m2 is 45m2 and land above 450m2 is the full 60m2. Site coverage is 200-250m2 is 65% of land 250-300m2 is 60% of land 300-450m2 is 55% and 450m2+ is 50% of land. Land cost has gone up with each release for example i bought june last year 488m2 for 538k which is $1100 a sqm you wont be able to find a block for that anymore. The smaller the block size the higher the price per sqm will be. As for the slab i have no idea yet as i dont no of anyone that has gone that far with the build. Hope all this helps Thanks! Do you know what the front and rear set backs are?(also rear set back for first floor) Typically Campbelltown Council has a 55% floor space ration, so on 600sqm that wouldn't be limited to 330sqm. Have I understood correctly? Thanks again. Hi, What is the source of this information "or secondsry building eg fonzi or granny flat land under 300m2 can only do maximuim 36m2 land 300-450m2 is 45m2 and land above 450m2 is the full 60m2" sssssssssssssssss Re: Building at Bardia - New Breeze 1176Oct 12, 2019 8:57 pm dolphin33 Hey guys, hows TPG NBN and Belong look like in our area? Are they any good? We just moved in last week and got TPG 50 MBPS NBN plan. Pretty good so far with no latency issues even while streaming rugby match last night out of Ten Play. Cannot comment on Belong, though. Re: Building at Bardia - New Breeze 1177Oct 15, 2019 2:09 pm Hi guys I have a provision to build studio on top of garage but due to financial constraints I have decided to do it later so I want to make sure my house plan does not obstruct in any way. Has anyone come across this situation and made necessary changes in house plan to comply studio construction at later stage. Re: Building at Bardia - New Breeze 1178Oct 15, 2019 10:29 pm dolphin33 Hey guys, hows TPG NBN and Belong look like in our area? Are they any good? No issue with Belong. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Building at Bardia - New Breeze 1179Oct 20, 2019 11:23 pm Hi everyone, Can some one please provide me some advice. I bought house and land package in Bardia signed contract last year, which was fixed price tender. And now the builder are charging me $5500 more because the fire rating from council came higher and need to upgrade some Of the stuff. Not sure if I have to pay this price. Has anyone had this issue before. Thanks For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9094 Is it just a report written to give to the bank initially and it is based on what and how your payments are made up for, or is it a full service where they go out and… 2 5599 Hi Suku18 In NSW the statutory required insurances are: 1. HBCF ( Home Building Compensation Fund) - This is if the builder dies or goes broke. But this only covers 20%… 1 2712 |
