Browse Forums General Discussion Re: Possible broken pipe .somewhere 2Sep 14, 2019 11:30 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 4Sep 15, 2019 12:09 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 6Sep 15, 2019 11:39 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 9Sep 15, 2019 12:31 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 12Sep 18, 2019 5:39 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 13Sep 18, 2019 5:59 pm Save, he spotted the issues when he put the camera down. He said he will come going and this time record video the pipes on usb. I've contacted the builder, if drains need to be replaced they said they may cover it on their builders warranty . Even though it's eleven years since house was built. But we will see. Re: Possible broken pipe .somewhere 14Sep 18, 2019 9:44 pm The problem with plumbing is that no one checks it and builders are also often caught out unawares. The builder's early advice to you to install ag pipes in all likelyhood was told to him by the plumber. There are builders who have decency and hopefully your builder will reflect on your earlier complaints about the plumbing and reflect on you being a wronged innocent party in someone else's doing. In fact, the builder also sounds like a wronged innocent party. I hope that it all works out ok. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 16Sep 20, 2019 5:45 pm Much appreciated luxbuild. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 17Sep 20, 2019 5:57 pm MyFirst Is flexi storm water pipe bad? Apparently yes. Non compliant according to plumber .It breaks easily. I have it connected to all my drainpipes. Except for one as plumber replaced it with proper connections I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 12882 yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6633 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36949 |
