Browse Forums General Discussion Re: Possible broken pipe .somewhere 2Sep 14, 2019 11:30 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 4Sep 15, 2019 12:09 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 6Sep 15, 2019 11:39 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 9Sep 15, 2019 12:31 pm clath I noticed you In the south east of Melb. I'm in pakenham are you a plumber? No, not a plumber. I research and design various products including plumbing products and drainage systems but I have cut back on my work load in recent years. I see a lot of endemic bad plumbing around the traps and strongly believe that an independent CCTV Cam inspection should be done on all new properties prior to handover. As is, nothing is inspected and non compliance is rife. Did you notify the builder within the 6 year period? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 10Sep 15, 2019 1:16 pm I told them about the drainage issues . Spoke them over the phone and emailed I've gone through my old emails . Only can find emails on other defects . I will still though ring them and email about this latest issue. Yes in hindsight a good idea about doing camera inspections before handover. Re: Possible broken pipe .somewhere 12Sep 18, 2019 5:39 pm It sounds like the stormwater pipes haven't been properly trenched and embedded. I don't know how the plumber could tell that the pipe was "being squashed/damaged by foreign objects" and that is a serious statement to make in writing. Proper embedment protects pipes from foreign objects when there is ground movement. Did the plumber give you a disc copy of the inspection? A good CCTV cam will also have a locator on it so that when a problem area is found, it can be pinpointed from above ground. Did he identify any above ground areas where the pipes had been damaged by foreign objects? 11 years is a long time and your area has had climatic variances during that time, it would be very difficult for any inspection to unequivocally ascertain the gradient that the pipes were originally laid. Did the plumber give you any idea as to the likely cost of rectification? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 13Sep 18, 2019 5:59 pm Save, he spotted the issues when he put the camera down. He said he will come going and this time record video the pipes on usb. I've contacted the builder, if drains need to be replaced they said they may cover it on their builders warranty . Even though it's eleven years since house was built. But we will see. Re: Possible broken pipe .somewhere 14Sep 18, 2019 9:44 pm The problem with plumbing is that no one checks it and builders are also often caught out unawares. The builder's early advice to you to install ag pipes in all likelyhood was told to him by the plumber. There are builders who have decency and hopefully your builder will reflect on your earlier complaints about the plumbing and reflect on you being a wronged innocent party in someone else's doing. In fact, the builder also sounds like a wronged innocent party. I hope that it all works out ok. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 16Sep 20, 2019 5:45 pm Much appreciated luxbuild. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Possible broken pipe .somewhere 17Sep 20, 2019 5:57 pm MyFirst Is flexi storm water pipe bad? Apparently yes. Non compliant according to plumber .It breaks easily. I have it connected to all my drainpipes. Except for one as plumber replaced it with proper connections I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 13204 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36991 0 10141 |
