Browse Forums Bathrooms and Laundry Re: Wall tap and mixer vs sink tap and mixer? Thoughts? Pros 3Sep 07, 2019 10:52 pm If you go in wall mixer taps just make sure you get a high quality one with long warranty. The only thing that goes wrong with them are the cartridges which can be replaced. You may have trouble getting replacements for no brand ones in future. Due the fact they are difficult to replace later on, I wouldn't go for matt black, brass or rose gold. Just stick to stainless steel which will never go out of style. I went with Methven. Re: Wall tap and mixer vs sink tap and mixer? Thoughts? Pros 4Sep 09, 2019 7:01 pm I'm deciding about the same thing at the moment, my thought was that wall mounted gets lots of splashing on the vanity when being turned off but a mixer on the sink the splashes land on the sink so less messy? Hadn't thought about the cleaning- are you referring to having to clean around the base of a mixer if its on the sink? Re: Wall tap and mixer vs sink tap and mixer? Thoughts? Pros 5Sep 09, 2019 7:56 pm BBJ Hadn't thought about the cleaning- are you referring to having to clean around the base of a mixer if its on the sink? Yes, the base where the tap meets the sink or benchtop is usually a pain to clean. Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12035 Were struck with: Colorbond Ironstone Grey roof and cream windows. What color should we render and paint the garage door to tone down the cream windows? Farm House, will… 0 26580 Have had stone benches with undermount sink (kitchen) and drop-in (laundry) and top-mounted basin (bathrooms) for coming up 13 years and not one chip/scratch of any kind.… 2 9676 |
