Browse Forums Building A New House Re: Advice on floor plans 8Sep 02, 2019 9:38 pm gillybean The first floor plan I actually much prefer over the second, the problem now is others like the second better, so now you have doubts and if you weren’t already second guessing yourself, you’re now. End of day you’re the one coughing up the money and have to live there. Honestly ask yourself which plan you prefer, and go with that (obviously). Thanks. Actually I want to resale after few years. So it is good to check which is a better plan and a popular plan Re: Advice on floor plans 9Sep 03, 2019 7:57 am Bebbsy I prefer option 2, the floorplan has a better flow. However the WIP now off the laundry does not make sense. Do you really need the pantry given the size of the scullery, which is the same size as your kitchen. And unless you are running a catering business from home, why would you have 4 sinks and 2 cooktops? Personally I would reduce the size of the scullery and increase the floor space in bedrooms 3 and 4. thanks for reply. Good point. In this case, the WIP should be WIL ( which should be used by Laundry). The idea for kitchen - light cook: use outside cooktop; for heavy cook: come to the scullery; maybe I should add a sliding door between scullery and the kitchen outside. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16562 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17898 |
