Browse Forums Building A New House 1 May 22, 2018 9:17 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Building defects? Owner?, The law is not your friend! 5May 23, 2018 11:30 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Building defects? Owner?, The law is not your friend! 7May 24, 2018 2:12 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Building defects? Owner?, The law is not your friend! 12May 27, 2018 8:16 pm Facebook group: https://www.facebook.com/groups/853390798159713/ Re: Building defects? Owner?, The law is not your friend! 13May 27, 2018 8:27 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Building defects? Owner?, The law is not your friend! 16Aug 30, 2019 11:15 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Building defects? Owner?, The law is not your friend! 17Aug 30, 2019 12:29 pm AandM How can owners protect themselves?! We had an independent inspector for every stage plus an extra visit to assist with a dispute during construction. We’ve been in our house more than a year and we’ve initiated a dispute over the brickwork, and we’ve learned that we have structural defects from the final inspection that were not rectified plus non-compliant mortar. Our builder has mentioned (splitting the cost of) rendering but has not provided evidence that the mortar is strong enough to last. Our engineers have recommended rebuilding the bricks. Apparently we will most likely end up thousands out of pocket for vcat before our builder will consider doing the right thing and get our house within compliance. It’s a nightmare. building-expert Most people would assume that if there are defects in your new building that the builder would be obliged to fix the defects. Whilst this is true and the builder is legally obliged to fix defects under builder’s warranty (10 years in Victoria) there may be a very nasty exception for defects that are very costly to fix. This could leave a building owner in a situation where there is only a cosmetic fix or a nominal compensation for a major defect. How is this so? It has to do with a common law precedent Belgrove vs Eldridge which in the interest of avoiding “economic waste” stipulates that rectification work will only be ordered where it is necessary to achieve conformance and further that it is a reasonable course of action to adopt. In other words, where the cost of rectification is disproportionate to the benefit to be gained the rectification will not be ordered. A particular example is say where Colorbond flat roof is specified but instead it is built in Zincalume. If there are no issues with town planning it seems that there is very little to be gained by removing air conditioners, lift the roof and replace roof sheets with Colorbond. A monetary compensation to the owner equivalent to the difference in cost between zinc and colour roof may seem appropriate. Now consider a scenario where you have a competent builder who has in place and maintains a quality assurance system. Errors and mistakes can still occur but the incidence and the severity of the rectification is likely to be lower and we could say that the builder has exercised due skill and care as required by warranties. I have no problem with such builder having the protection of Bellgrove vs Eldridge doctrine. However there are two scenarios that work in opposite direction. The first is the fact that quality supervision and the maintenance of a QA system is a costly item and there is a temptation to cut it back beyond the bone relying instead on tradies on site “to do the right thing” even if some have been screwed on price. The money that should be spent on supervision and QA instead is banked as builder’s bonuses. The second is that typically builders will take on more work than they can comfortably carry out, thereby stretching ever further what scant supervision there is. The result is that builders bank handsome profits (obcene perhaps) whilst short changing customers on delivery and quality and knowing they can do so with impunity because of our inept and corrupt building control system. Furthermore they know that if they truly blunder they may get escape ticket from Bellgrove vs Eldridge Australia is supposed to be a first world country but it is building its buildings without mandatory QA systems and delivering third world results as demonstrated by slab heave, multi storey cladding fiasco as well as poorly built, fire risky and leaking apartment buildings. Having spent last 15 years dealing with building defects and disreputable things done by reputable builders I would suggest that the protection of Bellgrove vs Eldridge against building defects should only be available to the builder if the builder can demonstrate the QA system was applied in full compliance. In all other cases it should be pull down and rebuild. Nothing works as well or as fast as when the builder has to pay for own mistakes. For the owner, the majority of potential problems can be avoided or dealt with competently by their own independent building stage inspector, performing inspections at critical stages of the build. It is always better to avoid building problems and defects rather than trying to deal with them afterwards. All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8325 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7141 1 9523 |
