Congratulations!!!. Does PCI mean Practical completion?
Browse Forums Building A New House Re: Building Windsor 40 with Eden Brae (Caddens) 42Jul 25, 2019 10:57 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 44Jul 25, 2019 11:22 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 46Aug 06, 2019 8:11 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 47Aug 27, 2019 12:08 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 48Aug 29, 2019 8:04 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 50Aug 29, 2019 5:43 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 53Aug 29, 2019 7:21 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 55Aug 29, 2019 7:33 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 57Aug 29, 2019 9:45 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 58Aug 29, 2019 9:49 pm InvincibleInDN Melbournevic Looking good. May I know how wide is your balcony and the sliding door in it? I am not a fan of a glass balcony so we will enclose it too similar to yours for more privacy. It's a good spot to enjoy coffee in the morning or watch sunset in the evening. The width of the balcony is 2780mm and the door width is 1800mm. The enclosure height is higher than my liking. Thanks. Almost the same as ours. I think the dimension is just right. I thought mine will look odd due to it smaller in size until I saw your post and it does look really good. Re: Building Windsor 40 with Eden Brae (Caddens) 59Aug 29, 2019 9:51 pm Melbournevic Thanks. Almost the same as ours. I think the dimension is just right. I thought mine will look odd due to it smaller in size until I saw your post and it does look really good. Thanks Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Building Windsor 40 with Eden Brae (Caddens) 60Sep 06, 2019 7:39 pm HI InvincibleInDN, Great to see your progress and have read all your posts and they are very very helpful. I am also in the build process with Eden Brae in Caddens and just about to have our Home Options appointment. Just curious to know if you have done the electrical fittings on both floors through Eden Brae and if they have have options to fit ceiling fan points on the rooms. Do they charge you extra for that. Also can you do the upper floor electrical wiring yourselves through your own electrician. Regards I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 33124 4 9901 How to calculate provision sum and margin? We are nearing completion and have received the final invoice which includes unexpected expenses for provisioned items. The… 0 14516 |
