Browse Forums General Discussion Re: Walk in Robe size - Opinions please 3Aug 25, 2019 4:58 pm My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Walk in Robe size - Opinions please 11Aug 27, 2019 3:08 pm Peter83 Hi everyone, What are everyone's thoughts on the size of our walk in robe and en suite? Size of WIR - L- 4m x W 2.4m Size of Ensuire - L 4m x W 2.01m Is the width of the WIR big enough? we are about to progress to working drawings and just want to be absolutely sure before i give the go ahead. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Instead of U shape - have it 2 parallel (left and shorter right). In the mid portion hang a gigantic mirror. Re: Walk in Robe size - Opinions please 12Aug 27, 2019 3:23 pm Hi, We are yet to have handover of our current build, but with all the cabinetry etc now installed we think our setup will work fairly well. Originally our plan had the ensuite entry via the bedroom but what concerned me was that door would be right next to the bed head area. Anyhow we chopped/changed on this design, but we think the pro's outweigh the con's for us. It gives more separation of the ensuite from the bedroom, also allows you to shower then dress in the robe more easily without disturbing someone else in the bedroom etc. We decided to not 'door off' the WIR itself as we didn't think we would honestly close it all that often anyhow. To assist with reducing condensation into WIR area, we made sure the ensuite door was only standard height (2040mm) and also we have a decent extraction fan and will make sure we leave it on for a while after showering. The size I think you have @2.4m width should be fine, as ours seems fine also at slightly less width than this. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ --------------------------------------------------------------------- Check our Homeone build blog here Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 8410 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3851 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7507 |
