Browse Forums Home Theatre & Automation Re: Very simple cabling question. 4Mar 16, 2009 2:17 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 6Mar 16, 2009 3:04 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 8Mar 16, 2009 3:29 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 10Mar 16, 2009 4:20 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 11Mar 16, 2009 7:17 pm Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: Very simple cabling question. 13Mar 16, 2009 9:27 pm I did wonder how many. I could only get 25mm conduit put in. Lucky for most I only want 2 cables per conduit. Plenty of room. Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 8671 thank you! do we need to get this or our builder before we commence new build on the block? 2 4418 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 6635 |
