Oh, that explains it. I have the same fascade on a Monte Carlo 42 ensuite except that I included extra garage.
Browse Forums Building A New House Re: Building with Wisdom Homes 14903Aug 15, 2019 7:20 pm Scaffolding all down today. Gyprock starts next week.. The swirls on the brickwork are just my photographic and uploading skills... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Manhattan 44 Ens + Savannah Elite facade KDRB Tender Accepted 26/03/18; Contract signed 27/05/18; CDC submission 24/10/18; End Panel 13/02/2019; Slab 19/03/2019 Re: Building with Wisdom Homes 14905Aug 16, 2019 1:17 am We had tiles on this week,so exciting becks81 How is everyone progressing? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 14907Aug 16, 2019 2:14 pm Always love seeing pictures of the progress everyone is making, Most of the people here are half way through constructions and probably get your house by Xmas. Ours is at the tail end of the admin process, pending the revision of our construction plan with a small error on one of our windows (rumpus rear). Taken 4 days to explain to our CSR we don't want a large window split into 3 smaller ones being built side by side. ml117 - interesting to see a Manhattan 44 with the door underneath the stairs. I am surprised that there is not enough height clearance for a full size door, especially when we have measured the would be door in the display home and on the plans itself. https://www.homeone.com.au/member/ml117 Manhattan52 - finally seeing someone's kitchen with the cabinetry behind the island bench with the same length. Ours is Manhattan44 and can fit 2 x oven, 1 fridge and a mini pantry (2 doors). Others with Manhattan 44 have only been 1 oven, 1 fridge and 1 pantry door. Re: Building with Wisdom Homes 14908Aug 16, 2019 2:21 pm M4bath Always love seeing pictures of the progress everyone is making, Most of the people here are half way through constructions and probably get your house by Xmas. Ours is at the tail end of the admin process, pending the revision of our construction plan with a small error on one of our windows (rumpus rear). Taken 4 days to explain to our CSR we don't want a large window split into 3 smaller ones being built side by side. ml117 - interesting to see a Manhattan 44 with the door underneath the stairs. I am surprised that there is not enough height clearance for a full size door, especially when we have measured the would be door in the display home and on the plans itself. https://www.homeone.com.au/member/ml117 Manhattan52 - finally seeing someone's kitchen with the cabinetry behind the island bench with the same length. Ours is Manhattan44 and can fit 2 x oven, 1 fridge and a mini pantry (2 doors). Others with Manhattan 44 have only been 1 oven, 1 fridge and 1 pantry door. M4bath True about the cabinetry. It’s a bad angle I was standing at though. Our kitchen island is 3m and the cabinetry is 3.7m. The ovens are 76 wide each and the fridge space is for 2 fridges joined together at 1.8m Re: Building with Wisdom Homes 14909Aug 16, 2019 2:33 pm Manhattan52 M4bath Always love seeing pictures of the progress everyone is making, Most of the people here are half way through constructions and probably get your house by Xmas. Ours is at the tail end of the admin process, pending the revision of our construction plan with a small error on one of our windows (rumpus rear). Taken 4 days to explain to our CSR we don't want a large window split into 3 smaller ones being built side by side. ml117 - interesting to see a Manhattan 44 with the door underneath the stairs. I am surprised that there is not enough height clearance for a full size door, especially when we have measured the would be door in the display home and on the plans itself. https://www.homeone.com.au/member/ml117 Manhattan52 - finally seeing someone's kitchen with the cabinetry behind the island bench with the same length. Ours is Manhattan44 and can fit 2 x oven, 1 fridge and a mini pantry (2 doors). Others with Manhattan 44 have only been 1 oven, 1 fridge and 1 pantry door. M4bath True about the cabinetry. It’s a bad angle I was standing at though. Our kitchen island is 3m and the cabinetry is 3.7m. The ovens are 76 wide each and the fridge space is for 2 fridges joined together at 1.8m Wow, yours is 3.7m long? Make sense since you have a 52 size and ours is only 44 with a 3m long. Others I've seen with a 44 is much smaller, made us double check, triple check many times over whether it was something we had missed. Ours is 1m fridge, 2 x 60 ovens with about 80 something for the pantry doors. Re: Building with Wisdom Homes 14910Aug 17, 2019 3:14 pm M4bath Manhattan52 M4bath Always love seeing pictures of the progress everyone is making, Most of the people here are half way through constructions and probably get your house by Xmas. Ours is at the tail end of the admin process, pending the revision of our construction plan with a small error on one of our windows (rumpus rear). Taken 4 days to explain to our CSR we don't want a large window split into 3 smaller ones being built side by side. ml117 - interesting to see a Manhattan 44 with the door underneath the stairs. I am surprised that there is not enough height clearance for a full size door, especially when we have measured the would be door in the display home and on the plans itself. https://www.homeone.com.au/member/ml117 Manhattan52 - finally seeing someone's kitchen with the cabinetry behind the island bench with the same length. Ours is Manhattan44 and can fit 2 x oven, 1 fridge and a mini pantry (2 doors). Others with Manhattan 44 have only been 1 oven, 1 fridge and 1 pantry door. M4bath True about the cabinetry. It’s a bad angle I was standing at though. Our kitchen island is 3m and the cabinetry is 3.7m. The ovens are 76 wide each and the fridge space is for 2 fridges joined together at 1.8m Wow, yours is 3.7m long? Make sense since you have a 52 size and ours is only 44 with a 3m long. Others I've seen with a 44 is much smaller, made us double check, triple check many times over whether it was something we had missed. Ours is 1m fridge, 2 x 60 ovens with about 80 something for the pantry doors. What has been the standard?? Ours is the ambassador so the island is orientated differently so what you are saying has never occurred to me. Re: Building with Wisdom Homes 14911Aug 17, 2019 3:15 pm melindaz We had tiles on this week,so exciting becks81 How is everyone progressing? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Taking shape!! Hope you’re happy. Re: Building with Wisdom Homes 14913Aug 17, 2019 5:28 pm Can't wait!! 😁😁 becks81 melindaz We had tiles on this week,so exciting becks81 How is everyone progressing? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Taking shape!! Hope you’re happy. Re: Building with Wisdom Homes 14915Aug 17, 2019 7:03 pm becks81 melindaz We had tiles on this week,so exciting becks81 How is everyone progressing? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Taking shape!! Hope you’re happy. How are you getting in to get photos? Re: Building with Wisdom Homes 14916Aug 17, 2019 7:51 pm GLO becks81 Looking great GLO!! Where are you up to? My scaffolding is down last week and have PCI in 2 weeks. Handover due mid September. Pool to be completed after handover though. Congrats GLO. Send more photos when you move in. Re: Building with Wisdom Homes 14917Aug 18, 2019 8:12 pm When we checked the house,the door was not locked! And we just go inside ti have a look 🤫🤫exciting Taking shape!! Hope you’re happy.[/quote] How are you getting in to get photos?[/quote] Re: Building with Wisdom Homes 14919Aug 22, 2019 12:55 pm Hello all, Whoever is in building phase, when can we expect to have the master plan with "doors/windows schedule"? All we have received so far are the plans with different elevations, none of them have the detailed windows/doors schedule. We have signed the contract, and have the selections soon. Thanks Re: Building with Wisdom Homes 14920Aug 22, 2019 2:57 pm sv_reddy Hello all, Whoever is in building phase, when can we expect to have the master plan with "doors/windows schedule"? All we have received so far are the plans with different elevations, none of them have the detailed windows/doors schedule. We have signed the contract, and have the selections soon. Thanks The door and window schedule for us is structural and was the first thing we did before signing the contract as the cost of the upgrades was in the very first tender. You better ask for it quick before they consider it a contract variation. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18435 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73284 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8207 |
