Browse Forums DIY, Home Maintenance & Repair Re: Sorting out Drainage 2Aug 06, 2019 11:50 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Sorting out Drainage 4Aug 13, 2019 8:26 am russellcook It'll be interesting to see if there's any tips for the second one. Where does the second one come from? You might need a smoke test to find out. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Sorting out Drainage 5Sep 30, 2020 1:08 pm I have a new house with 5 x 300 x 300 silt pits around my house with main storm water at the front. My pits only have one pipe i them and it appears to me they are to catch flood water from the yard then separate the silt. The rear two definately do not have the required 1 in 100 fall, they are sloping to the rear of the property and collect water. Front ones are maily dry and again only have one pipe for extraction. All pits are belwo where the paths, garden beds and lawn, needs to be as the whole area needs raising. Not getting any answers from the builder as to where they run, are connected to. Can these be removed and a riser put in above ground level? Re: Sorting out Drainage 6Sep 30, 2020 1:51 pm A silt pit's purpose is to trap silt before the water connects to the stormwater system, it is a regulatory requirement. You should ask a qualified drainer to attend on site and discuss with him. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 2 6396 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3453 13 7104 |
