Browse Forums Building A New House Re: Copyrighted Plans 3Aug 05, 2019 4:09 pm l_vanslyke Hi, Just a bit of background on myself; I work in the building industry as a building designer and see this dilemma on the regular. I have been involved in numerous court proceedings for copyright infringements of my own intellectual property. My advice to you would be NOT to use the plans in any way, shape, or form, don't even show them to the other builder. There is a common misconception that if you change the original work by 10%, you can avoid copyright infringement. It's simply not true. I can also advise that there is a very high chance the builder (Denis) will be checking the site to see what has been constructed and whether copyright has been infringed. They may also have access to view the lodged plans under FOI. Moving forward I would recommend finding a draftsman, building designer or architect and start a new from scratch. The $3,000 to $15,000 you'll spend on the new design could potentially save you hundreds of thousands on court proceedings and damages. Engaging a draftsman, building designer or architect allows you to shop around for a builder and compare quotes / tenders. I hope this helps and if you have any other questions please don't hesitate to PM me. This is perfect advice and exactly what i'm after. If we were to purchase the plans from Denis, i'm assuming that would be another scenario in which we could proceed legally? Thanks so much Re: Copyrighted Plans 5Aug 05, 2019 9:13 pm [quote="jbarber":3jmq0k7i][quote="l_vanslyke":3jmq0k7i]Hi, Just a bit of background on myself; I work in the building industry as a building designer and see this dilemma on the regular. I have been involved in numerous court proceedings for copyright infringements of my own intellectual property. My advice to you would be NOT to use the plans in any way, shape, or form, don't even show them to the other builder. There is a common misconception that if you change the original work by 10%, you can avoid copyright infringement. It's simply not true. I can also advise that there is a very high chance the builder (Denis) will be checking the site to see what has been constructed and whether copyright has been infringed. They may also have access to view the lodged plans under FOI. Moving forward I would recommend finding a draftsman, building designer or architect and start a new from scratch. The $3,000 to $15,000 you'll spend on the new design could potentially save you hundreds of thousands on court proceedings and damages. Engaging a draftsman, building designer or architect allows you to shop around for a builder and compare quotes / tenders. I hope this helps and if you have any other questions please don't hesitate to PM me.[/quote:3jmq0k7i] This is perfect advice and exactly what i'm after. If we were to purchase the plans from Denis, i'm assuming that would be another scenario in which we could proceed legally? Thanks so much[/quote:3jmq0k7i] Sorry, I forgot to respond to that part. You’re more than entitled too (and I encourage you) ask Denis if you can purchase the plans, however dont be surprised if they end up costing more than a custom design. If they do allow you to purchase the plans all you would need is their approval in writing and I’d recommend your solicitor check over it. Hope this helps! Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6990 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 14296 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4586 |
