Browse Forums General Discussion Re: door/ceiling 5Jul 31, 2019 8:08 am johnf Regular visual inspection is carried out. I was leaning towards just humidity/drought, but the door now hitting above the jamb brings a whole other concern. Any advice would be greatly appreciated. Hi Johnf Welcome to the forum Unfortunately visual inspections without Data is not enough from an engineering perspective For more definitive answers you will need to log δ changes against time (ie, Rate Of Change in Movement, Temperature,moisture, etc ) along with Photos. You can employ an expert consultant which can be costly or DIY using the right tools and then blue tooth the survey data to the consultant Bosch has a range of tools which will do all these for you Bosch Thermo Detector GIS 1000 C Professional Measure humidity and temperature Checking Wall & Floor Building Movement with Bosch Lasers The data from these tools are used in Simulations & in finding solutions Please leave a PM if you require urgent assistance, I'll be putting up examples here ASAP hth Cheers Chris . Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: door/ceiling 6Jul 31, 2019 4:19 pm insider Need photos inside and out to make any sort of judgement. Thank you Chris - I am new to this forum and am amazed at your kindness. My Mother-in-law is 90yrs old and lives 50minutes away. I have kept a close eye on everything for years and the company that we employed for the brick cracking outside used dozens of laser leveling techniques. As I said previously, I have found no movement or deterioration since. I will be going down there again in about a week to take some photos and will investigate the Bosch tools you've suggested. Once again thank you for your time and suggestions. johnf Re: door/ceiling 8Aug 09, 2019 9:29 am oldchippy Odd, on a concrete slab with no visible signs of cracking.For the door to be roughly 2-3 mm higher than the jamb means the hinge side must have gone down considerably.Termites? Wow thank you! I regularly keep an eye out around the internal and external perimeters of the house, as does the pest control people, but will now check thoroughly inside the linen cupboard cavity. I appreciate your time and response very much. I personally think pivot door are over the top, as you said a bit impractical having a small useless section and poor insulation. I’m pretty happy with a 920x 2040 with… 1 190 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5943 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 |
