Browse Forums Building A New House Re: Tips on building & private inspectors 3Jun 18, 2019 8:50 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Tips on building & private inspectors 5Jun 18, 2019 6:16 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 9Jun 19, 2019 7:55 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 11Jun 19, 2019 9:56 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 16Jul 26, 2019 7:51 pm Hi everyone, I'm looking to engage a private building inspector for my build, and wanted to check at which stages of the build people used the inspectors? I have had quotes from 2 different companies, one offers 4 or 5 stage inspection, and another says only 2 inspection is necessary?? (Pre-wall lining and on completion) I'm not sure which one would be better? Thanks! Re: Tips on building & private inspectors 17Jul 26, 2019 8:24 pm lozsyd and another says only 2 inspection is necessary?? (Pre-wall lining and on completion) I'm not sure which one would be better? Sounds like the second one is trying to secure their appointment with the lure of a lower price. A slab inspection is vital. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 18Jul 28, 2019 7:47 am This is what he said; I'm so confused!! As a Forensic investigator into residential compliance for a builder to inspect at slab and frame stages, it is unsubstantiated as the designing Structural Engineer certifies the slab which is your warranty The water-proofer and the PCA (Council) certifies their waterproofing which again is your warranty To inspect at just frame (pre lock up stage) is a waste of time as these works are incomplete It is just a money grab to do inspections at those stages and you don’t need it any thoughts?? Re: Tips on building & private inspectors 19Jul 28, 2019 10:11 am lozsyd As a Forensic investigator into residential compliance for a builder to inspect at slab and frame stages, it is unsubstantiated as the designing Structural Engineer certifies the slab which is your warranty Is this directly quoted text? If so, it is unprofessional garbled grammar. You are in NSW, do slab engineers inspect the slab pre pour where you are? If not, then how can slab engineers give certification and warranty? There are numerous cases on this forum of bad slabs, some haven't even been the correct height. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 20Jul 28, 2019 11:54 am Yes, it's a directly quoted text! Oh i have no idea about whether slab engineers inspect the slab pre pour! I also emailed another company and he also said he usually does the 2 inspections. However reading the forum it seems all 4 or 5 stages are crucial!! Might have to go with the first one who were the only ones to offer the 4/5 inspections as a package That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 82354 If you are in Victoria you have a statutory right to your own building inspector regardless of builder's consent. No negotiations are required. However the builder will… 1 3276 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12240 |
