when you say you are blind, is your condition stable? or will it get worse with time beyond what is normal for people growing older?
Because if you know that your eyes will get worse, then I would definitely recommend single story.
Browse Forums General Discussion Re: Feeling a little lost. 22Jul 16, 2019 7:41 pm My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Feeling a little lost. 29Jul 24, 2019 1:11 am My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Feeling a little lost. 31Jul 24, 2019 10:25 am I would hate to be the bearer of bad news, but you will not be able to build that house on that block. Firstly the house would need to be set back off the fence line (min 1 mtr for single storey) for compliance and also light/ventilation reasons (you can't have windows on the boundary). Most areas also call for a min 3mtr set back off the rear of the property. You would also need to comply with street set backs off the front of the house, and the side since you are on a corner. Your house is approx 27 mtrs long in the plan. Your block is 31 mtrs long. Street setbacks are usually around 6mtrs. The width is approx 12 metres, with your block approx 18 metres wide. With the front, side and rear setbacks, the house wont fit on the block. If you don't want go go down the double storey route, then you need to reduce the size of your home considerably. You measured a 314m2 plan (including terrace) on a 549m2 block. At best I think you could build a single storey of around 280m2 on that corner block, which would have the south and west facades being on the setback boundary, and a 3mtr strip for a backyard. I think even then, the house is still too large. With that said, that house could be reduced if you are set on a similar layout. The garage is huge (6.0 x 6.0 is plenty for two cars) The theatre room is pretty big for the house size also. You also have a corridor that's close to 30m2, or more than 10% of the floor plan. The living/dining could be re-configured to save space in the design, etc. Good luck with it all ! Blog is now up - http://www.jbdave.blogspot.com/ Re: Feeling a little lost. 32Jul 24, 2019 10:58 am To ben888 & the OP, there's more to consider than cost to your wallet when you're talking about house size. The initial & ongoing cost to the environment is great. The larger the home, the larger the CO2 production & resource usage required to build the home, & the larger the continued energy usage will be.
Australia has the highest rates of extinction in the world! Most of it due to climate change & habitat destruction. Yeah, you may say everything is fine, it's all BS, & consider it greeny nonsense. But let's just consider one example, the koala. It's already a threatened species, due to habitat loss from land clearing & climate change. Much of that land clearing is to create new housing estates up the east coast of Australia. Trends are only heading in one direction. To it becoming endangered, & if things don't change, likely extinct. Do we really want that. This is only one species. There's plenty of other species, that aren't iconic, or as cute & cuddly as the koala, that have already been lost. Household sizes have decreased, but we continue to build larger & larger homes, double the size of those from the past. Should we continue along this track, building estates of poorly designed McMansions, decimating bushland up the east coast, & losing some of the best farmland on the outskirts of Sydney. Or should we act, building well designed houses appropriate to our needs. The choice is ours. Build what is appropriate. If the OP rents out much of the home, or fills it with a family soon, then a reasonably large home may be appropriate. But if the OP is occupying a large 4/5 bedroom home by themselves it would be a great waste. Not only for themselves, but also at great cost to the environment. Re: Feeling a little lost. 33Jul 24, 2019 11:01 am You're not bearing bad news your just bringing some facts to the table! Appreciated. The design is a starting point but clearly a lot of aspects need to be locked at. I'm still confident i should be able to work with a builder and get a good end results. Doesn't bother me to much if i have to shuffle things around or reduce some size here or there. I guess the main things at this point are working out the restriction on where the house can be placed and general compliance, that will make it more clear what i have to do with my design. Re: Feeling a little lost. 34Jul 24, 2019 12:35 pm Generally, as has been mentioned, for a corner block the setbacks on the street frontages are the largest (probably around 4-6m), while the other two setbacks are much smaller (around 1m). This is different from a normal block which often has small side setbacks (around 1m), a medium front setback (~4m) & a large rear setback (~6m).
This varies from council to council. As does the maximum allowable build size, as a proportion of the block, which varies greatly for low, medium & high density zones. So yeah, as a starting point, check with your local council, to determine the zoning laws for your block. Re: Feeling a little lost. 35Jul 24, 2019 2:50 pm Not sure if this document is completely up to date but I've found this for the Lake Maurice council development Control Plan. Does the below seem about right? Street set back 1. Where there are existing adjoining residential buildings within 40 metres, i. the front setback must be consistent with the established setbacks or, ii. where adjoining building setbacks vary by more than three metres, the front setback must be the same distance as one or other of the adjoining buildings, or: iii. where adjoining buildings vary in setback, development must locate between their setbacks. 2. Where there are no existing (or approved) dwellings within 40 metres of the lot, the front setback must be a minimum of four metres from the front boundary. 3. The secondary street setback for corner allotments must be a minimum of two metres. 4. Entry features and porticos, porches, balconies, decks, verandahs, bay windows, eaves and awnings may encroach up to 1.5 metres into the front setback area. This encroachment must not cover more than 50 percent of building width. Part 3 – Development within Residential Zones LMCC DCP 2014 – Revision 20 Page 28 – F2016/01470 Adopted by Council 23 July 2018 5. Where the site is identified as being vulnerable to flooding or expected sea level rise, street setbacks may be reduced to ensure that developments are adequately setback from the shoreline. Rare setback 1. In the R2 and R3 zones, rear setbacks must be a minimum of three metres for buildings up to 4.5 metres in height. 2. In the R2 and R3 zones, rear setbacks must be a minimum of six metres for buildings over 4.5 metres in height, but less than three storeys. 3. In the R2 and R3 zones, the rear setback must be a minimum of nine metres for building height of three storeys or more . Side set back In the R2 and R3 zones, side setbacks must be a minimum of 900mm for building height up to 4.5 metres. 2. In the R2 and R3 zones, side setbacks must be a minimum of 1.5 metres for building height over 4.5 metres but less than three storeys. 3. In the R2 and R3 zones, the side setback must be a minimum of 3 metres for building height of three storeys or more. Re: Feeling a little lost. 36Jul 24, 2019 3:03 pm Personally, I think you're better off going to a reputable builder and talking to them. It costs nothing and until you sign a contract, it's free. You're allowed to get prices and information off them, and the reputable ones all know setback and best house orientation for your setup. Re: Feeling a little lost. 38Jul 24, 2019 10:23 pm @ddarroch it's great that you're promoting energy efficiency and thinking about environmental issues when building, but in terms of the build, the size of the house itself matters very little compared with all the other measures that are involved. Things like the actual build materials, the insulation of walls, floor, roof and windows, recyclable water, and energy efficient heating, cooling, lighting and appliances. You're better off having a 8 star rated larger house, than a 5 star rated smaller house. Nowadays, you can even build a whole zero-carbon skyscraper - which just shows size is not that important when in comes to being environmentally friendly! And besides, his plot size is already determined, so whether a 300m2 house or a 200m2 house is built, it's not going to encroach on any more natural habitat. My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Feeling a little lost. 39Jul 24, 2019 10:47 pm Bobo5050 Not sure if this document is completely up to date but I've found this for the Lake Maurice council development Control Plan. Does the below seem about right? Street set back 1. Where there are existing adjoining residential buildings within 40 metres, i. the front setback must be consistent with the established setbacks or, ii. where adjoining building setbacks vary by more than three metres, the front setback must be the same distance as one or other of the adjoining buildings, or: iii. where adjoining buildings vary in setback, development must locate between their setbacks. 2. Where there are no existing (or approved) dwellings within 40 metres of the lot, the front setback must be a minimum of four metres from the front boundary. 3. The secondary street setback for corner allotments must be a minimum of two metres. 4. Entry features and porticos, porches, balconies, decks, verandahs, bay windows, eaves and awnings may encroach up to 1.5 metres into the front setback area. This encroachment must not cover more than 50 percent of building width. Part 3 – Development within Residential Zones LMCC DCP 2014 – Revision 20 Page 28 – F2016/01470 Adopted by Council 23 July 2018 5. Where the site is identified as being vulnerable to flooding or expected sea level rise, street setbacks may be reduced to ensure that developments are adequately setback from the shoreline. Rare setback 1. In the R2 and R3 zones, rear setbacks must be a minimum of three metres for buildings up to 4.5 metres in height. 2. In the R2 and R3 zones, rear setbacks must be a minimum of six metres for buildings over 4.5 metres in height, but less than three storeys. 3. In the R2 and R3 zones, the rear setback must be a minimum of nine metres for building height of three storeys or more . Side set back In the R2 and R3 zones, side setbacks must be a minimum of 900mm for building height up to 4.5 metres. 2. In the R2 and R3 zones, side setbacks must be a minimum of 1.5 metres for building height over 4.5 metres but less than three storeys. 3. In the R2 and R3 zones, the side setback must be a minimum of 3 metres for building height of three storeys or more. Yeah, I had a quick look at your council rules, and they seem about right. So your building envelope will look something like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ But you've also got a rule on site coverage not exceeding 50% - which means that for your 549m2 plot, you can't build on more than 275m2 of it - so your 290m2 single storey idea is out! You've also got a Secluded Private Open Space rule of 24m2, minimum 4m width - which you can't build on - eg as I've pictured. My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Feeling a little lost. 40Jul 25, 2019 10:25 am ben888 @ddarroch it's great that you're promoting energy efficiency and thinking about environmental issues when building, but in terms of the build, the size of the house itself matters very little compared with all the other measures that are involved. Things like the actual build materials, the insulation of walls, floor, roof and windows, recyclable water, and energy efficient heating, cooling, lighting and appliances. You're better off having a 8 star rated larger house, than a 5 star rated smaller house. Nowadays, you can even build a whole zero-carbon skyscraper - which just shows size is not that important when in comes to being environmentally friendly! But don't forget about "embodied energy". It's not just about the energy it takes to operate a home, but also the energy it takes to manufacture & transport a home's components. This embodied energy is a significant proportion of the overall energy consumed over a home's life. Particularly if high embodied energy materials are used, like concrete, steel & aluminium. Obviously a larger home, built out of the same materials as a smaller home, will have a higher embodied energy. Also, other than getting orientation right (which is free), most improvements in energy efficiency come at a cost. Increasing insulation levels in the walls & ceiling, edge-of-slab or under-slab insulation (if it's appropriate), higher performing windows, solar PV panels, solar thermal or heat pump hot water, north facing polished concrete floors, heat recovery ventilation. Like most people, I'm sure the OP has limited funds. They're more likely to be able to afford some of these improvements if they save money on the build costs by building a smaller, well designed home, instead of a larger home. |
