Browse Forums Building A New House Re: Raised house 3Jul 22, 2019 6:04 pm I think they all build on stilts. They just don't have them shown in their designs. At least Burbank and... I think ?Clarendon ? said that. Although I think they avoid it if it slopes too much. Cost about 40k more. Best to call and ask. Re: Raised house 5Jul 23, 2019 7:12 am If it is only a metre it is no big deal. There are multiple construction methods that can suit, and if brick veneer is your choice, the most common would be strip footings and piers with a timber platform. Only a few more bricks . You should check with your council to see if there are any requirements to have the sub floor open to allow water egress. Consider going up another couple of hundred MM just for piece of mind. Our block has a 1:10 fall, so we opted for lightweight construction on duragal piers. We have 2.5m to the underside of the bearers, so you have plenty of options. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7035 How good is Simeon?! Always taking time to help others out! Wish we were building in NSW and could work together. Thanks for all that you do! 7 6585 Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6896 |
