Browse Forums Building A New House Re: Off the plan nightmare 2Jul 19, 2019 9:39 pm It's up to the developer to fix the issue. However, if it's a small developer, they may close the company down. I'd be checking everything with a fine tooth comb and not accepting settlement until everything is perfect, just assume it won't be fixed afterwards. Re: Off the plan nightmare 3Jul 19, 2019 9:43 pm The best advice I can give is read your contract. Generally it is up to the entity that you signed the contract to buy the unit from is who is responsible for presenting the unit in an appropriate condition for handover. I would assume that your contract is with the developer so it wll be up to the developer to engage a different builder to complete the works to an appropriate standard. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Off the plan nightmare 4Jul 19, 2019 9:47 pm Our lawyer is trying to delay settlement but it’s not easy to do. Do you know how I can check if our developer has closed his company down? Re: Off the plan nightmare 5Jul 19, 2019 9:50 pm JB1 It's up to the developer to fix the issue. However, if it's a small developer, they may close the company down. I'd be checking everything with a fine tooth comb and not accepting settlement until everything is perfect, just assume it won't be fixed afterwards. We are trying to stop settlement but as the certificate of occupancy has been issued it’s not easy to do. We are worried that nothing will be fixed once settlement has occurred. I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3121 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9084 1 2992 |
