Browse Forums Heating, Cooling & Insulation Re: Wall and Ceiling Insulation 3Jul 19, 2019 5:30 pm Mashee Is there anything extra they should add.We upgraded walls to 2.5 and ceiling to 5. Thanks For that R-value, they should install batts (or similar). However, they do that just before or while the plaster board goes on, otherwise, the insulation will just fall out. Re: Wall and Ceiling Insulation 4Jul 19, 2019 6:24 pm For that R-value, they should install batts (or similar). However, they do that just before or while the plaster board goes on, otherwise, the insulation will just fall out.[/quote] Thanks for the information. Found the answer. The recommended distance is .... 1 5989 Hi all, Just wondering if anyone had suggestions on installing/replacing wall insulation on an external wall which doesn't have wrap, our miners cottage being constructed… 0 4956 1 19743 |
