Browse Forums Building A New House Re: What size double storey will fit my land? 8Jul 03, 2019 6:16 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: What size double storey will fit my land? 9Jul 18, 2019 9:30 am Hi Vengeance In short, the max size is 250sqm and correct they will need to fall within the setback parameters if you were to go CDC. However there are many other factors that dictate, and they all play a part to the equation. Satisfying the controls is only a minor part to getting the build approved. Getting the design right to suit the land and your requirements while meeting all the controls is the art of custom designed home. There are pros and cons with both CDC and DA, and there is no right or wrong answer. Which method suits you best and achieve the most for you should be the question you need to ask. R.Koncept Architectural Design & Drafting Affiliate of the Building Designers Association Australia www.rkoncept.com.au Custom Home Designs | Additions & Alterations | Dual Occupancy Specialist 1 4592 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9983 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3550 |
