Browse Forums Home Theatre & Automation Re: Very simple cabling question. 4Mar 16, 2009 1:17 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 6Mar 16, 2009 2:04 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 8Mar 16, 2009 2:29 pm comes down to the ease of getting the cables pulled and being able to replace a single cable or both easier.....
any more questions call me Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 9Mar 16, 2009 3:12 pm Pugs comes down to the ease of getting the cables pulled and being able to replace a single cable or both easier..... any more questions call me So that makes it a legal requirement? wow, dont send the inspectors through any data centers! Thanks for the clarification. Re: Very simple cabling question. 10Mar 16, 2009 3:20 pm there are others but i CBF finding them call the acma if you really wan to find them out Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Very simple cabling question. 11Mar 16, 2009 6:17 pm don't send the inspectors my way!
I have squeezed 6 in a 20mm. I had to go through a sandstone wall that was heritage listed so I couldn't increase the hole. Lotsa lube and teasing got em in there. Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: Very simple cabling question. 12Mar 16, 2009 7:01 pm The Data Guys don't send the inspectors my way! I have squeezed 6 in a 20mm. I had to go through a sandstone wall that was heritage listed so I couldn't increase the hole. Lotsa lube and teasing got em in there. Way to go. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Very simple cabling question. 13Mar 16, 2009 8:27 pm I did wonder how many. I could only get 25mm conduit put in. Lucky for most I only want 2 cables per conduit. Plenty of room. Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11708 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9963 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6157 |
