This is the outcome of building with a long established project builder who claims quality. What are your thoughts with the mixer tap touching the shower frame?
Browse Forums Building A New House Re: Shower mixer tap touching shower frame...thoughts? 4Jul 12, 2019 11:46 pm that looks bad, but where is it on the plans? either someone screwed up the plans, or someone screwed up when reading the plans Re: Shower mixer tap touching shower frame...thoughts? 5Jul 13, 2019 7:11 am IsabellaBoots that looks bad, but where is it on the plans? either someone screwed up the plans, or someone screwed up when reading the plans Plans are correct. It all comes down to the tradie and SS. Error after error of not following plan. Re: Shower mixer tap touching shower frame...thoughts? 6Jul 13, 2019 7:49 am chanam KamadoJusto That’s crap For sure...it definitely is. Have seen many houses and have never ever come across one like this. Display home quality is questionable. Why’d you build with them in first place if their display home isn’t even ok? That tap position ordinary, but should’ve been discovered at rough in stage so a request to move it could’ve happened. Re: Shower mixer tap touching shower frame...thoughts? 7Jul 13, 2019 2:18 pm gillybean chanam KamadoJusto That’s crap For sure...it definitely is. Have seen many houses and have never ever come across one like this. Display home quality is questionable. Why’d you build with them in first place if their display home isn’t even ok? That tap position ordinary, but should’ve been discovered at rough in stage so a request to move it could’ve happened. Their display home is fine. It is the question of whether it is what you see is what you get. Very deceiving. Re: Shower mixer tap touching shower frame...thoughts? 9Jul 25, 2019 11:19 pm It looks like the shower rose will hit the floor if you drop it. Was there a shorter hose option? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Shower mixer tap touching shower frame...thoughts? 10Jul 26, 2019 12:45 pm Got to say from pictures which can be very deceiving, bathroom quality looks really good, was a very basic mistake as they would of known shower size and didn't fix which leads to why was it not picked up by anyone,supervision missing. Re: Shower mixer tap touching shower frame...thoughts? 11Jul 26, 2019 9:07 pm Joker Got to say from pictures which can be very deceiving, bathroom quality looks really good, was a very basic mistake as they would of known shower size and didn't fix which leads to why was it not picked up by anyone,supervision missing. Throughout build process, many errors picked up by owners and brought to attention of SS who always had an excuses after excuses. This is 100% true. You can not hang anything on steel frames. very frustrating 8 8017 I need to replace some lengths of aluminum shower frame but I can't seem to find any suppliers of this stuff. Neither the blue or orange home centers carry these things.… 0 5398 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7394 |
