Browse Forums Building A New House Re: What are these powerpoint and light switch??? 2Jul 12, 2019 1:12 pm CrazySmith See this video from 22 second to 28 second, can anyone tell me what are the powerpoint and light switch? Clipsal Iconic https://www.clipsal.com/iconicathome Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: What are these powerpoint and light switch??? 3Jul 12, 2019 2:56 pm Outlet looks like Iconic (but they don't seem to have USB one on their Web site), but light switch is smth different (man, those Iconic light switches are really ugly!) Similar SAA approved outlets at 1/10th of Iconic pricing: https://www.aliexpress.com/item/32792694818.html Bluetooth enabled switch is not a good idea either due to limitation on the number of BLE devices within the same area, Wi-Fi switches would be much better option. Re: What are these powerpoint and light switch??? 4Jul 12, 2019 4:55 pm The switches are CTEC http://www.ctec.com.au and are probably the best looking wifi switches available at the moment (still plenty of room for improvement though). They cost around the $120 mark for a 1 gang switch up to $145ish for a 3 gang. Do not buy any electrical gear from aliexpress, even just from the pictures you can see the switches don't even sit in the fitting properly, just like Arlec or Deta from Bunnings. Just terrible quality and you have a high risk of faulty straight out of the box with nowhere to return it. Re: What are these powerpoint and light switch??? 5Jul 13, 2019 12:30 am SAA switches from Alibaba suppliers need to be tested and evaluated on case by case basis. But most of the latest I have seen are comparable in quality with Clipsal or CTEC (in fact, CTEC is white labeling Chinese switches from Alibaba). Aliexpress I quoted above were just as an example, Alibaba provides much more options. But there were not pics over there where switches sit in the fitting, so I am not sure where do you see what they are not fitting properly. Re: What are these powerpoint and light switch??? 6Jul 13, 2019 12:38 pm TehJesus The switches are CTEC http://www.ctec.com.au and are probably the best looking wifi switches available at the moment (still plenty of room for improvement though). They cost around the $120 mark for a 1 gang switch up to $145ish for a 3 gang. Do not buy any electrical gear from aliexpress, even just from the pictures you can see the switches don't even sit in the fitting properly, just like Arlec or Deta from Bunnings. Just terrible quality and you have a high risk of faulty straight out of the box with nowhere to return it. Thanks, just found it. https://www.facebook.com/CtecSmartLightSwitch/ looks pretty good and we might go for this. Yes, NEVER buy electrical products from overseas, and even I avoid buying from eBay. Cheers Re: What are these powerpoint and light switch??? 7Jul 15, 2019 1:25 pm InvincibleInDN CrazySmith See this video from 22 second to 28 second, can anyone tell me what are the powerpoint and light switch? Clipsal Iconic https://www.clipsal.com/iconicathome Thanks, just checked with an electrician and confirmed it is Clipsal Iconic range. Re: What are these powerpoint and smart light switch? 9Aug 06, 2019 2:51 pm Is this Ctec switches? Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: What are these powerpoint and light switch??? 11Aug 06, 2019 2:53 pm TehJesus The switches are CTEC http://www.ctec.com.au and are probably the best looking wifi switches available at the moment (still plenty of room for improvement though). They cost around the $120 mark for a 1 gang switch up to $145ish for a 3 gang. Do not buy any electrical gear from aliexpress, even just from the pictures you can see the switches don't even sit in the fitting properly, just like Arlec or Deta from Bunnings. Just terrible quality and you have a high risk of faulty straight out of the box with nowhere to return it. Yes mate, I agree they are the best looking. Re: What are these powerpoint and light switch??? 12Aug 06, 2019 2:57 pm CrazySmith Yes mate, I agree they are the best looking. Looking good. I believe you upgraded your existing switches to CTEC. Did your house has neutral line running thru the switches? I am building with a volume builder and I have no idea how the wiring is done. I am planning to upgrade the switches on few places after handover. Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: What are these powerpoint and light switch??? 13Aug 06, 2019 3:02 pm InvincibleInDN CrazySmith Yes mate, I agree they are the best looking. Looking good. I believe you upgraded your existing switches to CTEC. Did your house has neutral line running thru the switches? I am building with a volume builder and I have no idea how the wiring is done. I am planning to upgrade the switches on few places after handover. Yes I have got neutral wire. You can request neutral wire from your builder and I think they can do it. Do the upgrade afterwards otherwise the builder will charge more. Also don't go for the cheap crap from eBay, I had some bad experience with those ones and finally dropped them in the bin. Re: What are these powerpoint and light switch??? 14Aug 06, 2019 3:04 pm CrazySmith Yes I have got neutral wire. You can request neutral wire from your builder and I think they can do it. Do the upgrade afterwards otherwise the builder will charge more. Also don't go for the cheap crap from eBay, I had some bad experience with those ones and finally dropped them in the bin. Too late ask the builder as they already started the painting. I am hoping they have done neutral line. But not sure. Thanks anyways Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: What are these GPO and smart light switch? ----installed 15Aug 22, 2019 3:33 pm was impressed by this video. Will do the same using this smart light switch https://www.facebook.com/watch/?v=891411724549463 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1195 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16262 |
