Browse Forums Kitchen Corner Re: Sink Strainer Plugs Not Holding Water 7Aug 27, 2014 4:27 pm Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: Sink Strainer Plugs Not Holding Water 12Jul 08, 2019 6:17 pm Hi All You are correct the bunnings kinetic did not work......still leaked even when we used 2 washers as suggested above So we made one out of a toilet cistern washer by cutting out the centre with a 1/4 inch chisel.........the outside diameter of the washer is slightly larger than the origional washer that lasted 14 years.. probably leaked for the last few years......our remedy has been to put vaseline on the rubber..........this did not last long........sent money it is fixed!!!! Re: Sink Strainer Plugs Not Holding Water 13Jul 09, 2019 9:34 am the cistern washer is J valve for a Elderware cistern branded hands bits that I have had for many years.........I have just made another one for the other sink waste..........I use the old washer to mark out a circle inside the washer .........then cut around with a sharp 1/4 inch chisel cutting the centre out ........it does not seem to have to be too accurate as when you tighten up it does not leak..........the second one has worked as well !!!!! 1 is free to air and the other 2 are for cable TV all of them completely useless in 2024 1 2267 Have had stone benches with undermount sink (kitchen) and drop-in (laundry) and top-mounted basin (bathrooms) for coming up 13 years and not one chip/scratch of any kind.… 2 9682 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6186 |
