Browse Forums General Discussion Re: Sealing and epoxy coating moist garage floor 2Jul 05, 2019 5:41 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Sealing and epoxy coating moist garage floor 4Jul 05, 2019 6:50 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Sealing and epoxy coating moist garage floor 5Jul 05, 2019 7:35 pm It mostly level, has some aggregate showing in a few places. And a few small areas I can patch. The main purpose is to have a cleaner looking floor which is easy to clean and stops the moisture coming through. Re: Sealing and epoxy coating moist garage floor 7Jul 06, 2019 12:32 pm 👍 Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Sealing and epoxy coating moist garage floor 9Jul 06, 2019 3:34 pm Epoxy coatings are oil and stain resistant. The one I applied is used in aircraft hangars and automotive workshops. It came from an industrial coatings supplier rather than Bunnings. I was concerned that it might be slippery as it is very shinny however we've had no issues even when it's wet You can seed it with silica beads when you apply it to make it non-slip, however it is harder to keep clean then. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Sealing and epoxy coating moist garage floor 10Jul 06, 2019 4:07 pm chippy Epoxy coatings are oil and stain resistant. The one I applied is used in aircraft hangars and automotive workshops. It came from an industrial coatings supplier rather than Bunnings. I was concerned that it might be slippery as it is very shinny however we've had no issues even when it's wet You can seed it with silica beads when you apply it to make it non-slip, however it is harder to keep clean then. Thanks! Any photos of yours? Re: Sealing and epoxy coating moist garage floor 11Jul 06, 2019 5:50 pm chippy Epoxy coatings are oil and stain resistant. The one I applied is used in aircraft hangars and automotive workshops. It came from an industrial coatings supplier rather than Bunnings. I was concerned that it might be slippery as it is very shinny however we've had no issues even when it's wet You can seed it with silica beads when you apply it to make it non-slip, however it is harder to keep clean then. I agreed with you Chippy. I also think that they might be slippery. Re: Sealing and epoxy coating moist garage floor 12Jul 06, 2019 6:02 pm GLO chippy Epoxy coatings are oil and stain resistant. The one I applied is used in aircraft hangars and automotive workshops. It came from an industrial coatings supplier rather than Bunnings. I was concerned that it might be slippery as it is very shinny however we've had no issues even when it's wet You can seed it with silica beads when you apply it to make it non-slip, however it is harder to keep clean then. Thanks! Any photos of yours? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 3 5895 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18019 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7004 |
