Browse Forums Building A New House Re: Building a Metricon Glendale 42 Limited Edition in Melbo 363Jul 05, 2019 11:55 am We have returned from Fiji and walked through the build today as no trades on site. Lots has happened while we were away, the most exciting being the scaffolding is down and we can see the true exterior with all render now done and painted. Downpipes are installed and fixing has been done with skirts, architraves and doors installed – although some of the doors need to be realigned as hubby works in industry and won’t put up with anything less than perfect! Kitchen island has had the cupboards redone in the correct colour and cut outs have been done for downlights and exhaust fans. There are a few small things that need to be rectified and we will bring that up at our next walk-through in the coming weeks once SS is back from leave. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a Metricon Glendale 42 Limited Edition in Melbo 364Jul 05, 2019 12:06 pm Looking great! Love the look of the shed. You will definitely have lots of landscaping to do. Are you planning to have backyard pool? There is plenty space for one. Re: Building a Metricon Glendale 42 Limited Edition in Melbo 365Jul 05, 2019 12:10 pm Ramee Looking great! Love the look of the shed. You will definitely have lots of landscaping to do. Are you planning to have backyard pool? There is plenty space for one. Thanks ramee, yes we would like a pool at some stage, possibly in the next couple of years. We would put it on the opposite side of the backyard to the shed, just outside the outdoor room. Definitely lots of landscaping to do, but luckily the block is dead flat, except for a small drop off at the rear over an easement. We may just put a rockery there to stagger down to the rear fence. Re: Building a Metricon Glendale 42 Limited Edition in Melbo 366Jul 05, 2019 1:40 pm How exciting to get back from holidays to that Looks awesome shokel1975 Re: Building a Metricon Glendale 42 Limited Edition in Melbo 368Jul 05, 2019 6:22 pm Look amasing. You should go on holidays more often. Re: Building a Metricon Glendale 42 Limited Edition in Melbo 370Jul 06, 2019 10:58 pm shokel1975 We have returned from Fiji and walked through the build today as no trades on site. Lots has happened while we were away, the most exciting being the scaffolding is down and we can see the true exterior with all render now done and painted. Downpipes are installed and fixing has been done with skirts, architraves and doors installed – although some of the doors need to be realigned as hubby works in industry and won’t put up with anything less than perfect! Kitchen island has had the cupboards redone in the correct colour and cut outs have been done for downlights and exhaust fans. There are a few small things that need to be rectified and we will bring that up at our next walk-through in the coming weeks once SS is back from leave. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I thought I was looking at my internal doors for a second. Your photo popped on on tapatalk's main page. I have similar timber translucent doors for my bathrooms. Regarding your internal doors, are you planning on staining your timber doors? I'm debating if I should stain my a darker colour. If your doors are anything like mine, I suggest you change your hinges to solid ball bearing hinges as the glass doors are heavy. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a Metricon Glendale 42 Limited Edition in Melbo 372Jul 06, 2019 11:17 pm JB1 shokel1975 We have returned from Fiji and walked through the build today as no trades on site. Lots has happened while we were away, the most exciting being the scaffolding is down and we can see the true exterior with all render now done and painted. Downpipes are installed and fixing has been done with skirts, architraves and doors installed – although some of the doors need to be realigned as hubby works in industry and won’t put up with anything less than perfect! Kitchen island has had the cupboards redone in the correct colour and cut outs have been done for downlights and exhaust fans. There are a few small things that need to be rectified and we will bring that up at our next walk-through in the coming weeks once SS is back from leave. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I thought I was looking at my internal doors for a second. Your photo popped on on tapatalk's main page. I have similar timber translucent doors for my bathrooms. Regarding your internal doors, are you planning on staining your timber doors? I'm debating if I should stain my a darker colour. If your doors are anything like mine, I suggest you change your hinges to solid ball bearing hinges as the glass doors are heavy. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi JB1, yes Metricon will be staining ours in Black Japan. Thanks for the heads up re the hinges. My hubby installs fire doors so he will definitely know if this is needed. I will get him to look at it after handover. Cheers! Re: Building a Metricon Glendale 42 Limited Edition in Melbo 373Jul 06, 2019 11:20 pm MyFirst Nice toilet. But I reckon u need to keep some spare tiles. Anything wrong with the toilet flusher u need to hack the wall to access it. We will be having a concealed cistern toilet in the powder room just like this pic. The staff at Reece confirmed to us that any repairs required would just be within the box behind the flush plate. I hope this is the case as we will have tiled walls also. Re: Building a Metricon Glendale 42 Limited Edition in Melbo 374Jul 07, 2019 8:44 am MyFirst Nice toilet. But I reckon u need to keep some spare tiles. Anything wrong with the toilet flusher u need to hack the wall to access it. I have 2 boxes of spare tiles, but maybe I should keep 4, just in case. As mentioned above, you can change the float and valve from the button panels. Reason I went for Reece brand compared to a no name toilet is they should keep.spare parts for a long time. Worst comes to worst, you could access 2 of the 4 toilets from behind rather than tile in front. shokel1975 JB1 shokel1975 We have returned from Fiji and walked through the build today as no trades on site. Lots has happened while we were away, the most exciting being the scaffolding is down and we can see the true exterior with all render now done and painted. Downpipes are installed and fixing has been done with skirts, architraves and doors installed – although some of the doors need to be realigned as hubby works in industry and won’t put up with anything less than perfect! Kitchen island has had the cupboards redone in the correct colour and cut outs have been done for downlights and exhaust fans. There are a few small things that need to be rectified and we will bring that up at our next walk-through in the coming weeks once SS is back from leave. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I thought I was looking at my internal doors for a second. Your photo popped on on tapatalk's main page. I have similar timber translucent doors for my bathrooms. Regarding your internal doors, are you planning on staining your timber doors? I'm debating if I should stain my a darker colour. If your doors are anything like mine, I suggest you change your hinges to solid ball bearing hinges as the glass doors are heavy. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi JB1, yes Metricon will be staining ours in Black Japan. Thanks for the heads up re the hinges. My hubby installs fire doors so he will definitely know if this is needed. I will get him to look at it after handover. Cheers! It's not needed but it will swing more freely. Butt hinges wear out over time as the metal rubs against each other, more so on a heay door. What brand door is it and the thickness of tje glass? Sticker looks like Corinthian. Did you have much pushback or concern from people with a translucent bathroom door? My friends thought I was crazy. shokel1975 MyFirst Nice toilet. But I reckon u need to keep some spare tiles. Anything wrong with the toilet flusher u need to hack the wall to access it. We will be having a concealed cistern toilet in the powder room just like this pic. The staff at Reece confirmed to us that any repairs required would just be within the box behind the flush plate. I hope this is the case as we will have tiled walls also. Did you also purchase from Reece or order via the Builder? Re: Building a Metricon Glendale 42 Limited Edition in Melbo 375Jul 07, 2019 9:45 am Yes I think doors are Corinthian, not sure without checking our files. We are still building so not sure what people will say about using these on powder room! Haha! We ordered through Metricon after visiting Reece to make our selections. We upgraded every vanity, tap, bath, toilet, etc Re: Building a Metricon Glendale 42 Limited Edition in Melbo 376Jul 07, 2019 10:05 am those doors are LIN1 hume doors ( I have a few also) link below https://www.humedoors.com.au/ranges/internal/52-joinery-internal/348-lin1 Re: Building a Metricon Glendale 42 Limited Edition in Melbo 377Jul 07, 2019 10:09 am stanus those doors are LIN1 hume doors ( I have a few also) link below https://www.humedoors.com.au/ranges/internal/52-joinery-internal/348-lin1 Oh yes you are right, thanks stanus, they are Hume. Re: Building a Metricon Glendale 42 Limited Edition in Melbo 379Jul 07, 2019 2:35 pm Shokel, I noted downpipes aren't connected. Make sure its connected asap. Hmmm I'm debating if I should stain my doors. I'm worried it will be too dark against my blackbutt flooring. Once you stain there's no going back. At this stage I'm looking to leave it natural with satin waterbased enamel. Other issue with staining is my staircases have lots of screening so I would need to match it too. Doulton777 I didn't want it too dark. Re: Building a Metricon Glendale 42 Limited Edition in Melbo 380Jul 07, 2019 3:12 pm JB1 Shokel, I noted downpipes aren't connected. Make sure its connected asap. Hmmm I'm debating if I should stain my doors. I'm worried it will be too dark against my blackbutt flooring. Once you stain there's no going back. At this stage I'm looking to leave it natural with satin waterbased enamel. Other issue with staining is my staircases have lots of screening so I would need to match it too. Doulton777 I didn't want it too dark. Thanks JB1, will request they get connected ASAP Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10732 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8179 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17330 |
