Browse Forums Heating, Cooling & Insulation 1 Jul 04, 2019 10:17 am I have a Solar thermal hot water service. It works great during summer with the heat element switched off at switch board. October to April/May no electricity is used to heat water. On the other hand during the cooler months I find the system does not work well, requiring the electrical element to heat the water. The outcome from this is winter electricity bills are huge. I have found a few articles from europe and usa about the benefits of using Solar thermal hot water with a heat pump back up but nothing in Australia. Has anyone seen this in Australian? Thoughts? Matt Solar thermal Hot Water with Heat pump tank 2Jul 04, 2019 6:08 pm Matt A I have found a few articles from europe and usa about the benefits of using Solar thermal hot water with a heat pump back up but nothing in Australia. Can you provide a link? I'd like to see exactly what they are talking about. Matt A On the other hand during the cooler months I find the system does not work well, requiring the electrical element to heat the water. The outcome from this is winter electricity bills are huge. Could you connect the hot water tank to the concessional/off-peak rate? Solar thermal Hot Water with Heat pump tank 3Jul 05, 2019 1:30 am arcadelt Matt A On the other hand during the cooler months I find the system does not work well, requiring the electrical element to heat the water. The outcome from this is winter electricity bills are huge. Could you connect the hot water tank to the concessional/off-peak rate? This is what we did. Get a sparky to do it for you. Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17539 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10833 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1670 |
