Browse Forums Building A New House 1 Jul 04, 2019 12:16 am Hi all Clarendon built my home in 2015. We have two fire alarms in a single level home. They started chirping today ! I opened the cover and got the shock of my life (use with pun) when I discovered that the alarm was not hard wired. All it had was the usual 9 V battery. For the last four years I had been thinking that both the alarms are hardwired. Even the cover of the alarm has the words “A.C. power”written on it. Can anyone confirm if Clarendon hardwire their alarms .... should this thing be in the contract, if yes, where should I look ? Thanks you Re: Fire alarm by Clarendon Homes 2Jul 04, 2019 12:26 am Are you sure they aren't hardwired with a battery backup? They typically chirp to let you know to replace the battery even if they are hard wired. Interesting... Built with Eden Brae Now building with Fairmont Homes NSW Re: Fire alarm by Clarendon Homes 5Jul 04, 2019 9:08 am The three little metal prongs just above the battery push up into the base when you close it. All the wiring is behind. As others have mentioned the chirping noise is to alert you that the batteries have lost power and need replacing. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5251 Need some advice. Living in a townhouse with one common wall, recently we have discovered that the fire separation wall is incomplete and on further investigation, support… 0 3867 Not back peddling at all. You seem to have issues with comprehension my friend. Guy fcked up, he's considering being dishonest with his bank and hiding it. It will end… 21 14274 |
