Browse Forums General Discussion Re: Build Inspection on every stage - worth it and which sta 2Jul 02, 2019 1:48 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Build Inspection on every stage - worth it and which sta 4Jul 03, 2019 3:08 pm ![]() I was told that Pre Slab might not be necessary too as that is done properly normally by engineers (or someone - can't remember) Pre slab is absolutely necessary, probably the most important in my opinion. Yes it is "checked" by the building surveyors inspector but I wouldn't trust that. If they were doing their job properly independent inspectors would never find anything, and yet they do. Our building surveyor's inspector must have been legally blind or didn't even bother to get out of the car. Our post slab was checked at frame stage. Re: Build Inspection on every stage - worth it and which sta 5Jul 03, 2019 3:20 pm ![]() I was told that Pre Slab might not be necessary too as that is done properly normally by engineers (or someone - can't remember) Was told to do the following 1) Post Slab 2) Frame Stage 3) Pre-Plaster Stage 4) Fixing Stage 5) Pre-Handover Stage An example: https://www.newhomeinspections.com.au/pricing/single-dwelling/ Suggests: Pre Slab, Frame, Pre-Plaster, Pre-Handover Another example: https://www.buywiseinspections.com.au/new-home-inspections Suggests: Pre-Plaster, Fixing Stage, Pre-Handover And then https://www.jimsbuildinginspections.com.au Suggests: All the above stages (1-5) Pre slab is incredibly important as you need to check that termite collars are installed, sewer and drainage pipes are in the correct location and the specified reo has been used Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Build Inspection on every stage - worth it and which sta 7Jul 05, 2019 10:00 am Thanks guys.. I understand there is mixed reaction and both sides of the coins From the three links given above, could anyone recommend or list them on preference? Still trying to decide to go for, which stages and with whom? Re: Build Inspection on every stage - worth it and which sta 8Jul 14, 2019 6:30 pm Based on advice I had and my experience at minimum I’d recommend Pre slab!!!!!!! Very important but you do need to have someone who knows what they are doing. I’d worry about any service saying pre slab pour wasn’t important in Victoria at least where engineer does not come to site. As someone said above slab (post slab) can be inspected at frame stage as it’s visible. Frame stage Pre plaster PCI/pre handover (I would add an inspection at fixing stage if you were not confident that work was being rectified) Re: Build Inspection on every stage - worth it and which sta 9Jul 30, 2019 10:22 am Hi All I've read all the comments here, very valuables, I also believe that pre-slab inspections is vital as you can detect problems ahead of time and avoid expensive corrections. Now I have not been able to find a company in Sydney that offers that. Does anybody have a company in Sydney that does it? That will be of great help. Cheers I'm currently doing the building permit via my local architect. My understanding is after I have it approved, I'll be looking for builders' quotes to progress with the… 0 419 Thank you so much for your advise. Yes, I think I will find the building company who can build my house. I am working more than full time and understood after 6 months… 2 1063 4 1794 |
