Browse Forums Building A New House Re: Metricon - Savannah 40 - Adelaide Athelstone 86Jun 19, 2019 10:08 pm data for daysLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ sinksLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ master to ensuiteLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ showers installedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ baths installedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ showers installedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ showers installedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ robe paintingLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a thing of beautyLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ facade looking goodLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ temp scaffold up for more cedarLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ temp scaffold up for more cedarLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ fences replacedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ fences replacedLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ more joineryLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ laundry completeLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ robesLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ linenLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ robesLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon - Savannah 40 - Adelaide Athelstone 87Jun 20, 2019 11:06 am That's a big update! Everything looking on point, really love all your choices. Re: Metricon - Savannah 40 - Adelaide Athelstone 89Jun 22, 2019 2:41 pm What is your networking setup and did Metricon install it for you? Re: Metricon - Savannah 40 - Adelaide Athelstone 90Jun 22, 2019 11:27 pm Renman What is your networking setup and did Metricon install it for you? Hubby set ours up Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ viewtopic.php?t=86597 Re: Metricon - Savannah 40 - Adelaide Athelstone 91Jun 23, 2019 2:07 pm @D777 Can I get your hubby to do my one for me too? Lol Re: Metricon - Savannah 40 - Adelaide Athelstone 92Jun 26, 2019 10:35 am Renman What is your networking setup and did Metricon install it for you? Cat 6 all ran back to garage with a 16 port gigabit switch, couple of patch panels, just plug in the modem and away you go. We have NBN to the premise but will probably just put a 5G modem in there as it's available in our area and min 10x faster than NBN. Re: Metricon - Savannah 40 - Adelaide Athelstone 93Jun 26, 2019 10:36 am Renman @D777 Can I get your hubby to do my one for me too? Lol Hahahah sure. When he finds the time viewtopic.php?t=86597 Re: Metricon - Savannah 40 - Adelaide Athelstone 94Jun 26, 2019 12:15 pm craigo Renman What is your networking setup and did Metricon install it for you? Cat 6 all ran back to garage with a 16 port gigabit switch, couple of patch panels, just plug in the modem and away you go. We have NBN to the premise but will probably just put a 5G modem in there as it's available in our area and min 10x faster than NBN. Did they terminate the Cat6 cables with a RJ45 connector for you? They are refusing to do it for our build stating that it's not in their scope? Re: Metricon - Savannah 40 - Adelaide Athelstone 95Jun 26, 2019 3:32 pm Renman craigo Renman What is your networking setup and did Metricon install it for you? Cat 6 all ran back to garage with a 16 port gigabit switch, couple of patch panels, just plug in the modem and away you go. We have NBN to the premise but will probably just put a 5G modem in there as it's available in our area and min 10x faster than NBN. Did they terminate the Cat6 cables with a RJ45 connector for you? They are refusing to do it for our build stating that it's not in their scope? Some builders do, some don't , Mine did but it doesn't not matter , However, since it was outside the brick wall the connector all was dusty and expose to moisture. So I have to redo them. Re: Metricon - Savannah 40 - Adelaide Athelstone 96Jun 26, 2019 3:32 pm Renman Did they terminate the Cat6 cables with a RJ45 connector for you? They are refusing to do it for our build stating that it's not in their scope? That's so random! All ours were done, they even supplied the switch. Re: Metricon - Savannah 40 - Adelaide Athelstone 97Jun 26, 2019 6:03 pm dulie Renman Did they terminate the Cat6 cables with a RJ45 connector for you? They are refusing to do it for our build stating that it's not in their scope? That's so random! All ours were done, they even supplied the switch. Building a new home, and looking for a garage builder (home builder not contracted to do this). Someone to build steel garage (double), colorbond, including supply and… 0 3256 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10759 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8205 |
