Browse Forums Building A New House Re: Tips on building & private inspectors 3Jun 18, 2019 8:50 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Tips on building & private inspectors 5Jun 18, 2019 6:16 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 6Jun 18, 2019 6:21 pm In my case building with Metricon I employed an inspector and learnt from him by accompanying him on the inspections. I then bought the necessary tools and inspected myself every week in the company of the SS. I also engaged NSWDFT to inspect. I documented and photographed every identified variance to standards and sent this to Metricon in a spreadsheet supporting the NSWDFT rectification order. Amending this as defects were corrected or negotiated. The construction standards are readily available from state governments and the inspection tools are inexpensive at Bunnings. Many times I was told by Metricon that defects had been corrected but upon checking they weren’t. Some defects took a few gos to correct. Try 5 times for bathroom waterproofing! You have a contractual right to inspect your build and reasonable access is once a week, or more regularly after works are done. Do not pay the progress payments unless the work that is reasonably expected to be complete and defect free for each stage has been done properly. Don’t wait for surprises when it’s too late, or believe Metricons verbal assurances that they will fix things later. Often they won’t. Re: Tips on building & private inspectors 7Jun 18, 2019 6:37 pm I’m just worried about missing things when I go to inspect, as I can’t have an inspector with me every time I go (which would likely be 1-4 times a week). Any tips on this? Still a bit confused about this. Like Norfolk said, noticed issues & had to tell them multiple times fix it i.e. bathroom waterproofing. I’m concerned I may not be able to identify it as still ‘defective’ after they’ve told me they’ve “fixed it”, or even find this problem in the first place. Does anyone have any good building inspectors to recommend? Re: Tips on building & private inspectors 8Jun 18, 2019 6:43 pm Housepect were good. Also make sure you understand the standards and the work. don’t accept the builders assertions it’s ‘fixed’ Their KPI is finish the building stage ASAP to get the next payment so fixed means something different to them! Quality is not a KPI in Metricons case. If they feel you are naive they may take advantage of this. Make the builder explain things and don’t accept anything until you can be sure it’s ‘fixed’ and you fully understand it. You are paying $500k plus and should demand quality. Unfortunately Metricons business model does not include any quality assurance process for the build, it’s all false marketing and sales representations about quality with no substance behind it. Re: Tips on building & private inspectors 9Jun 19, 2019 7:55 am Reiri36 I’m just worried about missing things when I go to inspect, as I can’t have an inspector with me every time I go (which would likely be 1-4 times a week). Do you know that you need the builder's permission to do this? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 10Jun 19, 2019 9:33 am SaveH2O Reiri36 I’m just worried about missing things when I go to inspect, as I can’t have an inspector with me every time I go (which would likely be 1-4 times a week). Do you know that you need the builder's permission to do this? As the land owner you have the right of access to your land under consumer law , they can only prevent you from entering if they had a lease , you have given them a licence to build a house on your land Consumer law is above what they put in a contract. They can issue a stop work notice on ohs grounds if you become a nuisance. If they were like our builders the site was never locked gates and fences always left open along with house even when lock up was reached. Anybody could walk in off street under these circumstances. Re: Tips on building & private inspectors 11Jun 19, 2019 9:56 am Tim65 As the land owner you have the right of access to your land under consumer law , they can only prevent you from entering if they had a lease , you have given them a licence to build a house on your land Consumer law is above what they put in a contract. I was refering to a new home buyer turning unanannounced 3-4 times a week. The owner and/or their appointed representative do have a right to visit but the site is under the builder's control and there are also OHS laws to abide by. The owner does need permission to enter the site. Tim65 If they were like our builders the site was never locked gates and fences always left open along with house even when lock up was reached. Anybody could walk in off street under these circumstances. What you have described is totally unacceptable and a bad reflection on the builder. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 12Jun 19, 2019 10:07 am Reiri36 I’m just worried about missing things when I go to inspect, as I can’t have an inspector with me every time I go (which would likely be 1-4 times a week). Any tips on this? Still a bit confused about this. Like Norfolk said, noticed issues & had to tell them multiple times fix it i.e. bathroom waterproofing. I’m concerned I may not be able to identify it as still ‘defective’ after they’ve told me they’ve “fixed it”, or even find this problem in the first place. Does anyone have any good building inspectors to recommend? Ok, There are a number of really good and informative answers. I believe that as customers the only fair chance we've got to be successful is to share information. Re: Tips on building & private inspectors 13Jun 19, 2019 10:08 am Apologies for that, I meant to add this link to a document that helps with inspections https://www.fairtrading.nsw.gov.au/__da ... rances.pdf Download the NSW Guide to Standards and Tolerances 2017 (PDF, 2045.25 KB) Cheers Re: Tips on building & private inspectors 14Jun 19, 2019 10:09 am I'm afraid I'm going to have to eat my words above in post 2. I stand corrected by Building Expert. In Victoria now in order to register as a Building Inspector, either Limited or Unlimited, you need to complete either an Advanced Diploma or a Bachelors Degree. You don't ever have to have built anything however. Also Building Inspector is a name legally limited to those who are registered building inspectors for mandatory statutory inspections for a Building Surveyor so not what you are after if I understand you correctly. Building Expert is a building consultant or property inspection expert and he has been a builder himself. Re: Tips on building & private inspectors 15Jun 19, 2019 3:17 pm The consultant said it would be fine to visit, and by 1-4 times a week I included just watching from outside (i.e. across the road, for example when they’re doing the slabs and framework etc). I had read posts and it seemed like lots of people very visiting multiple times a week so I assumed this wouldn’t be an issue. Not sure how we’ll go. Re: Tips on building & private inspectors 16Jul 26, 2019 7:51 pm Hi everyone, I'm looking to engage a private building inspector for my build, and wanted to check at which stages of the build people used the inspectors? I have had quotes from 2 different companies, one offers 4 or 5 stage inspection, and another says only 2 inspection is necessary?? (Pre-wall lining and on completion) I'm not sure which one would be better? Thanks! Re: Tips on building & private inspectors 17Jul 26, 2019 8:24 pm lozsyd and another says only 2 inspection is necessary?? (Pre-wall lining and on completion) I'm not sure which one would be better? Sounds like the second one is trying to secure their appointment with the lure of a lower price. A slab inspection is vital. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 18Jul 28, 2019 7:47 am This is what he said; I'm so confused!! As a Forensic investigator into residential compliance for a builder to inspect at slab and frame stages, it is unsubstantiated as the designing Structural Engineer certifies the slab which is your warranty The water-proofer and the PCA (Council) certifies their waterproofing which again is your warranty To inspect at just frame (pre lock up stage) is a waste of time as these works are incomplete It is just a money grab to do inspections at those stages and you don’t need it any thoughts?? Re: Tips on building & private inspectors 19Jul 28, 2019 10:11 am lozsyd As a Forensic investigator into residential compliance for a builder to inspect at slab and frame stages, it is unsubstantiated as the designing Structural Engineer certifies the slab which is your warranty Is this directly quoted text? If so, it is unprofessional garbled grammar. You are in NSW, do slab engineers inspect the slab pre pour where you are? If not, then how can slab engineers give certification and warranty? There are numerous cases on this forum of bad slabs, some haven't even been the correct height. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Tips on building & private inspectors 20Jul 28, 2019 11:54 am Yes, it's a directly quoted text! Oh i have no idea about whether slab engineers inspect the slab pre pour! I also emailed another company and he also said he usually does the 2 inspections. However reading the forum it seems all 4 or 5 stages are crucial!! Might have to go with the first one who were the only ones to offer the 4/5 inspections as a package That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81919 If you are in Victoria you have a statutory right to your own building inspector regardless of builder's consent. No negotiations are required. However the builder will… 1 2962 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11779 |
